Switching the 350w BPM motor on my Big Bear for a 500w one
Andy Bluenoes
849
305
55
uk
It is illegal for use anywhere the public has access.
Cyclotricity won't tell you that, of course.
It's not illegal to sell or possess the bike, so you could buy it and hang it on your wall without breaking any laws.
It is illegal to use it in 1000 watt mode in public areas, but not in 250 watt mode I believe.
RobF
4,732
2,312
Sorry, power restricting switches are no get out to the legislation.
RobF
4,732
2,312
Its not a switch...by default the bike has 250 watts...only by making changes in the control panel can it be derestricted
Makes no difference, and in any event the bike in 1,000w mode is illegal to use anywhere you could realistically ride it.
If that wasn't enough, the power cut off speed of 15.5mph is also non-negotiable, irrelevant to the size of the motor.
Andy Bluenoes
849
305
55
uk
I'll agree to disagree on that one.
Reactions: RobF
RobF
4,732
2,312
That's probably a good idea in forum debating terms, but I do suggest you check the legislation before buying.
I am not strongly against someone using such a bike responsibly, but I do strongly object to companies misleading their customers.
If as a company you are going to encourage someone to break the law, you should at least make them aware they will be doing it.
trex
7,703
2,671
What does 10A - 20A mean? Is there an adjuster?
I can't remember. The last time I opened one was in 2014.
rated: 10A
Maximum: 20A
Andy Bluenoes
849
305
55
uk
To be fair, Cyclotricity are fairly clear in that it is illegal to use this bike out of standard mode anywhere but off road. The bikes are supplied in 250 watt mode, and unless you sign off a disclaimer, they will not provide the method to derestrict it..... Yes, no doubt that is to cover themselves, which in my mind is fair enough.
Wether the buyer then decides to disregard that afterwards is their choice. So, I dont think they are misleading anyone at all. Just like everything else in life, be it driving a car at 30 mph in a 20mph zone etc
RobF
4,732
2,312
At the risk of going around in circles, the bike is illegal to use 'off road'.
Cyclotricity are misleading customers badly to suggest anything else.
Reactions: Andy Bluenoes
Andy Bluenoes
849
305
55
uk
Ah well, now you've presented the law so intricately, I guess I'll hang mine on the wall when it turns up tomorrow then.
RobF
4,732
2,312
Believe what you like, but the law is clear.
RobF
4,732
2,312
I havent seen you produce anything to confirm your interpretation of the law, thats the problem.
Plenty on here and elsewhere if you search.
And if you do your own legwork, you might believe it.
Not that I'm suggesting it's the most serious criminal offence in the world, but if you hit someone while riding the bike you may not know - legally - what hit you.
The criminal penalty is not that severe, but a competent personal injury solicitor could bankrupt you by way of a personal injury claim.
Ride it responsibly and the chances of anything nasty happening are low, but to be properly informed you should be aware of the risk you are running.
D8ve
2,142
1,294
Bristol
It hasn't been tested in court yet. The law says an off road switch is illegal. How much reprogramming is required to switch the power is something that a lawyer would love to ask ( at reasonable rates). Same thing with the motor. It is rated 250 watts, having it also rated as 1000watts makes it kind of dubious. But there are some(all?) other manufacturers doing similar.
So they are pushing the boundaries. Enjoy but don't come crying to Rob if you get hurt.
Andy Bluenoes
849
305
55
uk
Its seems i may be eating humble pie for breakfast.....
It does appear to be a very grey area however.
I intend only on riding it legally if such a way does exist with this bike, so thank you for the heads up ;)
Reactions: chris_n and D8ve
RobF
4,732
2,312
As you've now gathered, you have two humps to get over - speed limit and motor power.
Speed limit is fairly straightforward, the motor cannot assist above 15.5mph, although there is a measurement tolerance of an mph or two.
If you set the limit to, say, 16.5mph, you would be legal from that point of view.
Motor rating is a grey area, not least because all motors can deliver far more peak power than their nominal rating.
But the only figure in the regulations is 250w, described as a maximum.
You would be riding a bike with a published maker's spec of 1,000w.
So straight away you are very much on the back foot, if not obviously illegal.
RobF
4,732
2,312
The motor is stamped as 250 watts
That could be helpful, although in the unlikely event a lawyer was trying to nail you, he would seek to make strong connection between your bike and its marketing as 1,000w.
