Suspension seat post
LeighPing
2,547
1,945
The Red Ditch
I'd like to strongly recommend this - BikeHut Bike Bicycle Alloy In-Line Suspension Seat Post - 27.2mm 28.6mm. It's a quality basic seatpost that has a 28.6mm shim included, if you need that particular size of shim. I didn't use the shim, but I did use one of the 3 differing weight springs that are also included.
It's very well made with strong components and the springs are well greased.
Reactions: Kinninvie
Andy Bluenoes
849
305
55
uk
View attachment 18768 View attachment 18767
Tempted to get one of those....dont want to spend loads as Ive never tried one before.
Is the tilt angle of the seat adjustable with it?
Reactions: LeighPing
LeighPing
2,547
1,945
The Red Ditch
I had to jiggle the 2 bolts to get it level and right for me. Initially the back stuck up because I'd tightened one off completely too soon. The rounded plate at the bottom is loose and turns to whichever way you want it to.
I just did a test ride and took my 5 year old grandson for a 'backy', sat on the bikerack bag. Solid.
Reactions: Andy Bluenoes
Andy Bluenoes
849
305
55
uk
OK, cheers.....my seat is quite a lot higher in comparison to yours....i could actually do with my handle bars higher but thats another story........ so I tend to try and get the front of the seat pointing slightly up...looks like that lower U piece is serrated to move it up or down a bit which would work
Andy Bluenoes
849
305
55
uk
I don't think that it is serrated. I'll go take it apart and see..
Dont do that if it means losing your position.....Im hoping to have my atrocity back on the road for the weekend, and need to nip to halfords to get a new brake cable so can take a closer look when i go :)
LeighPing
2,547
1,945
The Red Ditch
Too late.. I wanted to know anyhow. It's not serrated. However it locks in pretty good with the two bolts. I did before and after pics 'jumping on the seat' type tests, simulating an extreme cross country ride. It never budged at anytime. So, here's a few pics in different positions. The most angled, back and forth, that I could do.
DSC01284.JPG DSC01286.JPG DSC01289.JPG DSC01290.JPG DSC01291.JPG DSC01292.JPG DSC01293.JPG DSC01285.JPG
The bolts are of good quality. Quite often they're made of cheese! :oops:
Andy Bluenoes
849
305
55
uk
Perfect, thanks for doing that, loads of adjustment there.
I'll reserve one from halfords and pick it up over the weekend. Should be great for the atrocity, and transfer to the new one later on :)
mountainsport
1,419
298
View attachment 18775 View attachment 18777 View attachment 18780 View attachment 18781 View attachment 18782 View attachment 18783 View attachment 18784 View attachment 18785
Good illustrations LeighPing.
Andy Bluenoes
849
305
55
uk
Put the post on this morning....what a difference it makes!
Cant obviously compare to an expensive one as I have never tried one, but for £12, its an absolute bargain.
Thanks for the tip LeighPing ;)
Andy Bluenoes
849
305
55
uk
The middle one...I'm just on the border in terms of weight for that and next one up but it seems fine
Sent from my BUSH SPIRA D3 5 using Tapatalk
