SR Suntour Hub Flylead/Connector
3,729
ripped it all apart again and found a slight uneven backplate where its been crunched - cleaned up and oiled it instead - seems better at least - agree though, its a shocking design for the price!
Finally back together - and looks like it works - in other words its not giving errors and reads the speed etc ok. when i pedal and turn on assist is spins up the back wheel in pulses - no idea if that's because its in the air and the torque sensor isn't detecting changes in torque or something - never ridden it so don't know how it behaves.
Lets hope the nephew looks after it this time...considering it's his way to work you'd hope so!!
Thanks for all the help on here - really got me through this mess!
I'm now looking for a better specced "project" e-bike for myself - with a crank housed motor....can't be doing with all these bare wires and custom brake discs etc lol :) I've got a full suspension pedal only Cube MTB which i built myself and love, but after years of saying i'd never get an e-bike, dodgy knee ligaments are now forcing me to reconsider.... Expect me around again soon :)
There are two signals to the controller that go down separate wires. One has a pulsing signal for how fast you're pedalling, which is given by the light going through the castellations. The other is a 5v analogue signal given by measuring the length of the pulses, which decrease as you pedal harder. The actual operation is pretty well fool-proof regarding the electronics and the way it gets those signals, so any intermittence in the power is more likely to be a connection problem. If the chain comes off, it normally damages or pulls the wires into the tplastic part, so have a good look at those, or you can test them with a meter if it packs up completely.
One other thing that I forgot to mention is that you can remove a couple of springs to get maximum power with less pedal effort.
smifee
70
76
Chandler's Ford
I had knee ligament problems last year. Couldn't cycle and had to go up the stairs one step at a time.
NHS rest but use advice followed but did not work.
Read about zero drop aka barefoot footwear. Tried a pair and the problem went away instantly.
Now have zero drop walking boots, slippers, shoes & steel capped boots.
Baz the balloon man
274
10
Hi if you have any more major problems Carrera .
Strip all the e bits out sell any good ones on here or e bay and put after market bits on it .
Then you will not get stitched up for the cost of new Carrera Parts.
The Cranks , PAS sensors and lcd screens are sort after SH because they are shite !!!! And fail .
Baz the balloon man
274
10
Hi Big
As this post is about fixing a Suntour Motor is it ok to add to it ?
only I just part x a Suntours motor for a food delivery guy it’s just spinning .
He has been using a 52V battery on a Carrera Subway to do his deliveries I advised him to get a 36V battery or he would burn out the nearly new motor I sold him.
I also just bought in a Vengence around 800 miles on the meter with Error 43 on the LCD .
I checked all the controller connections that seem to be fine I am going to test the motor today with a different controller.
As an internal motor Virgin repair er I plan to open them both up and try and make one working motor from them the one with error 43 probably has the least miles .
I will post some photos once I have them on the bench and have a good read off your posts .
Cheers
Baz
