Splitter for lighting?
8,594
Front light with integrated horn, horn is type found on electric pallet truck. Light is bright enough for commute/town riding.
https://www.aliexpress.com/store/product/universal-voltage-24-48v-wuxing-QD139-2-headlight-frontlight-LED-light-with-horn-for-electric-scooter/1314442_32687071343.html?spm=2114.12010612.8148356.6.244811baR88Is5
Rear is wired in P with front and utilises the light/horn outlet from the dual volt KT controller.
Controller has double wired outlet for light and the switch.
anon4
574
90
32
GB
Ok I've ordered some lights, do you think I need a fuse if using the KT input? I have a KT controller coming with the light port. I believe the lights can be controlled via the KT LCD 3 so I haven't bothered with a switch yet
anon4
574
90
32
GB
Oh I see it has the switch input, will order ine
8,594
Fuse not required if using the light/switch input.
Reactions: anon4
anon4
574
90
32
GB
Cool, the battery has packed up in my rear light that was the last straw, looking forward to hopefully more reliable lighting. Did you do anything to protect or reinforce the wires?
8,594
All I have done is kept all wiring tidy inside 6mm spiral wrap.
