Speed Sensor? Torque Sensor?
Speed Sensor with less cost? Or spend more money for Torque Sensor?
  • Speed Sensor is enough for me
  • Torque Sensor is everything!
Results are only viewable after voting.
That's right. It's like deciding what's best out of roast pork or roast chicken.
17,440
seriously, there is a third option besides cadence sensor and torque sensor, the new 6-degree gyroscopic sensor.
bmsbattery may be on something here with their all in one kit.
Wisper Bikes
6,341
2,297
70
Sevenoaks Kent
You can pedal as hard as you want with either system, but you on a cadence system, you control the amount of assistance you want with your brain, not how hard you pedal.
Surly both use the brain, on to send signals to your foot and one to your hand! :)
All the best, David
17,440
Reactions: Wisper Bikes
https://bmsbattery.com/home/857-all-in-one-hub.html
They have an app that talks to the controller over Bluetooth 4.0
I am sure d8veh is going to put me right on this. I think that the controller uses the 4 dollar MPU-6050 gyro/inclinometer to work out how much assist to give, replacing the expensive torque sensor and LCD.
Yes, it's just a regular sensor like you have in your phone (unless you're a Luddite, like Flecc), but it's only a sensor. It's what the controller does with the information that matters, the same as a torque or cadence sensor. Nevertheless, it's still a brilliant idea to automatically adjust the power as you go up and down inclines, but I don't think many people would want that.
Reactions: mike killay
17,440
have you tried out their all in one hub? I must say I am tempted to buy a sample.
I guess they use the inclinometer to replace the assist level.
You only need to tell the controller how much you want to pedal (eg 70W), the controller works out how much current to supply.
No, I haven't tried one.
Yes, the gyroscope thing makes a very clean install and solves the problem of buttons on the handlebars. With a torque and/or rotation sensor and a battery in the hub, you don't need any wires at all. I guess I'm a bit old-fashioned with these things, but I prefer to have control myself rather than hand over to automatic systems. I guess that eventually they'll get these sort of systems perfect, then I'll have to let go of my old ways.
17,440
I have a bottom bracket controller on a new bike. Unfortunately, Hatti does not think it will sell and she knows our customers better than I do. She also said it'll take in water...
mike killay
3,012
1,629
Guess I am a bit of a Luddite too.
To me,
Add complications,
Add unreliability.
Reactions: Benjahmin
GLJoe
853
407
UK
I think that the controller uses the 4 dollar MPU-6050 gyro/inclinometer to work out how much assist to give, replacing the expensive torque sensor ...
Ok, I'm scratching my head, but I can't work out how that could replace a torque sensor.
How would it do that ??
17,440
The torque sensing is not needed, what is needed is an algorithm to calculate how much current is required.
This is just me theorising, if you need to know the torque, you may need the MPU-9150 instead of MPU-6050 because the 9150 has a magnetic sensor built in on top of the gyro/inclinometer. A magnet ring on the BB can be used to derive the RPM while the gyro can be used to calculate the speed, the inclinometer gives the gradient. You compute the required power from speed and gradient, subtract the motor output to get user input, then deduce the torque from user input power/rotational speed in rads.
mike killay
3,012
1,629
OR
You use a twist throttle.
The whole concept is to have everything in the hub - no wires at all. You do some basic setup with a smart-phone to set the power according to your weight or fitness. The hub detects when you pedal via its own torque or cadence sensor inside the hub. You start riding and the system knows whether you're going uphill or downhill via the gyro sensor. It adjusts the power accordingly to keep the pedal effort within the parameters that you set with your phone.
Like everything, there are advantages and disadvantages.
GLJoe
853
407
UK
Ok, but that is all well and good if all you want to do is cycle at a constant input effort all the time. In real life and in complex situations, a cyclist would be varying and controlling the power delivered to the bike, often in a dynamic and constantly varying way.
To do this on a normal bike, your brain is constantly scanning with your eyes and altering the power via your leg muscles. If you want to augment this with an ebike motor, you have to somehow tap into the info that the brain is producing if you want to maintain this fluid, dynamic cycling experience.
You could try drilling electrodes into your head (!?!), however a far less painful method seems to be to measure the force exerted onto the pedals! i.e. use a (good quality) torque sensor.
I don't see how anything else can produce the amplified 'natural cycling' experience that many people find very satisfying and prefer.
I completely understand that some people don't want to/can't put the effort in to adequately operate a torque only based system, hence why a switchable system does sound ideal. However you can only switch off something that is already there. You can't switch in something that is missing in the first place, so I personally am all for pedelecs (as distinct from electric mopeds) that have torque sensors! Anything else just isn't cycling ;)
17,440
it is not practical to respond immediately to variations in the torque sensor output which itself varies cyclically with the crank angle. The torque sensor helps to maintain an average ratio of cyclist pedal power / motor power. That job can equally be done with the data collected from the gyro.
GLJoe
853
407
UK
Yes, I can imagine that you might not want a direct, instantaneous 1 to 1 relationship (although pondering this as I write - wouldn't that be exactly what happens with a powerful cyclist just cycling normally on a non powered bike?)
But you could (and they probably do) start playing around with peak detection algorithms with smoothing etc to try and counter that if you didn't want it.
However I'm still puzzled as to how data from a gyro sensor can detect how much power you are/want to input ??
(but I'm still pondering. There is a power meter out there that works out rider input without actually using a torque sensor! I forget its name, but it sits on the front bars and measures inclination, speed, and also wind).
The motor does have a torque sensor in it. The gyro sensor adjusts the eco/tour/sport or level 1/2/3/4/5 setting automatically.
