Yes i did.It's 53.4 voltDid you measure the battery's voltage o see ifthe LCD is reading correctly. You should measure it directly onthe battery terminals plus on the connector where the LCD plugs in. Be very careful not to short any pins in that connector when you're measuring.
The battery is ok.The problem is with display unit (configuration of display/remote)
For testing i've exchange the unit to identical one and it shows 53+
That's why i'm pretty sure that the problem is with configuration of monitor/remote (not sure what is correct name of the display )
It's like somehow display was configured for more than 48 volt capacity and now it's not showing correct voltage
