Specialised Crosstrail conversion
You can contact them through Alibaba. My last contact was with Shine Wang email mxus012@hotmail.com.
IIRC all the girls had emails mxus??@hotmail.com where ?? Is a number like 04, 05, etc.
Unseen
59
49
Manchester, UK
Hmm will have to give that a try... the email I sent to was E-mail:panjun@mxusebikekit.com.
@d8veh How does the kit suggested by whoosh seem in comparison to the one you suggested?
One thing I have found frustrating finding ‘the right kit’ is the amount of either 36v offerings (and usually sold out in 700c) or 48v but only to find they’re direct drive, especially the eBay kits.
The MXUS motor is a cassette one. It's a large diameter like the BPM so it can handle a lot of current. A 48v motor will make 30% more torque than the same motor at 36v with the same current.
Unseen
59
49
Manchester, UK
EEK! 30% damn... Thought it was more 10% ish based on reading other threads.. More torque more likely to shift the load better I guess?
Probably for discussion another time but is there any particular reason it seems hard to find the MXUS motors (or 48v motors) in the UK? Find it wierd can pick up 48v bbs02's and direct drive is pratically thrown at you but geared nope...
Unseen
59
49
Manchester, UK
Well I'm waiting for an email back from MXUS now (after I blundered around alibaba!!).
I went back to BMSBatteries though as a thought, they have the BPM2 so did a quick price up:
Bafang BPM2 48V500W Rear Driving E-Bike Motor Wheel
SKU : MT00014RPM : 201
S12S 500W Torque Simulation Sine Wave Controller
S-LCD6 LCD Meter for S-Series Controllers
Dual Hall Sensor 12 Signals Easy Assembling PAS
Not bad for £151.... Then £143 shipping!! All in £295 I know it's the wheel killing the shipping so dropped an email to my LBS asking for a price for a 700c wheel built with the motor.. Just waiting to hear back from them as without the wheel it's £220 shipped.
Have I missed anything obvious with this lot? The motor I spec'd it as the 201RPM/210 (with the wheel?!?) remembering something you said @d8veh about going for lower rpm more torque should be able to lug me around!
I did get to have a very very short play on a bike with a BBS fitted when I took a trip out to valley ebikes in bolton... Initially was a little sluggish (probably wrong gear as well) but once the pedal moved a bit further wooosh! I get the manic grin now :)
If you can get one, get the BPM1 instead of the BPM2. It has the easily removable side-plate in case you ever need to regrease the gears.
You'll also need a battery. The S12 S is about 26 amps, so you'll need one with a continuous discharge rate of 30 amps. You can try Eclipse Bikes for one of their batteries with the 30Q cells, but they're often out of stock. If they haven't got any, you'll need to go further afield. have a look at Em3ev.com and Lunacycle.com.
Unseen
59
49
Manchester, UK
Hmm I'm confused with that one unless BMS are using the wrong pictures? The image they show looks like there is a screw off plate?
Would I be better with a controller from PSWPower? I tried to find one that matched the power of the motor without going OTT
As for the battery, I seem to be swaying to this route so would either wait for Eclipse or contact BGA
They not only post the wrong pictures, but they also post the wrong motors too. It would be best to make it clear to them that you want the BPM one, and hope that they know what it is.
Unseen
59
49
Manchester, UK
Ugh, that I didn’t want to hear! Is there a supplier you recommend d8veh or do you go direct when your ordering ?
Feels like if your happy with a lower power setup, buy locally but if you want a specific spec they make you work for it. I think you mentioned MAC motors before but they seem to go off windings rather than rpm?
Reading through some more threads would a xiongda fit the bill? I assume that would be another alibaba purchase?
You buy Xiongda kits direct from Xiongda. The two-speed motor is excellent for heavy people. In low gear it gives immense torque like a winch. Once instaĺed, it would give you everything you want. The problem is the installation. The motor is quite wide, which makes it a bit more tricky to fit, so OK if you're good at that sort of thing, but not for first-timers, who want plug and play.
Xiongda also make a copy of the BPM motor - the YTW-05. Xiongda give the very best customer service and are relarively cheap. You should send an email to bonnie @xiongdamotor.com.cn. Tel her that you want"
Qty 1 48v 500w YTW-05 rear motor speed around 32km/h
Qty 1 KT controller
Qty 1 LCD
Qty 1 thumb throttle
Qty 1 PAS
You can ask if she has a suitable battery to go with it. I'm not sure whether they do batteries too. They will send you an invoice that you can pay with Paypal.
Don't expect delivery next week. Allow about 3 weeks from payment
Neil5403
213
16
Staffs, England ST15
I too have a Specialised Crosstrail for conversion, but want a smaller more lightweight conversion for it. I will start another thread on it, as do not want to hijack yours. Will be interested to see what you end up with and how it looks/performs.
