Spare Charger Oxygen S-Cross CB
Tony gallagher
15
45
Uk
Battery def not charged I just took for a ride and nothing and yes dbye I ordered the one in your link in your first post
DBye
166
78
Possibly, sorry don't mean to sound patronising but it's just to sanity check. My charger has a label on that says 42v, 2A, centre positive, does yours too?
Easiest way to check if dodgy is with a multimeter if you've got one.
Other sanity check, is the kettle lead fully plugged into the brick and is the fuse in the plug good?
Tony gallagher
15
45
Uk
Yeah checked all of that mate all the same changed fuse etc just gonna get one from oxygen pay the extra so I know it will work thx for your time though dbye I appreciate it
You were asked twice to measure the charger's voltage, but you didn't give the answer.
Tony gallagher
15
45
Uk
I haven't got a boot metre, I've ordered a new one from oxygen now somil let you know how I get on with that one. Thx
Is your original Oxygen charger available and working. If not, you've just wasted £50.
JuicyBike
1,671
527
Derbyshire
Just a thought... Would it be sensible to check the battery fuse?
17,434
the fuse, if there is one, should still be OK. The LED on the charger went red for a second before going green, signalling that the charger shuts itself down because either the battery voltage is too low or the BMS has a fault.
TG, can you check the battery's voltage?
DBye
166
78
Just to confirm there is a 30Amp blade fuse located in a separate compartment under the charge point, well at least on mine!
17,434
that's for the output.
The charging port is usually not fused.
DBye
166
78
@Woosh -ahh I see what you mean, you're quite right. I've not identified a fuse for the input.
Tony gallagher
15
45
Uk
Juicy your a legend, I just checked the battery fuse and it's broke lol all that trouble for a teeny tiny fuse hopefully it will work when replaced.
Thx for all the help guys it's much appreciated
Reactions: VictoryV
JuicyBike
1,671
527
Derbyshire
Let's hope that burned fuse isn't an indicator of a more serious problem. It's not likely, but I'm always happier if I can understand why any fuse has blown.
Tony gallagher
15
45
Uk
It was certainly the problem, if it happens again il have to investigate further thx again juicy.
