Solar trailer build
matthewslack
2,594
1,671
You've certainly proven that a trailer solar panel set up is ideal for long range touring. Its just such a large size. Is there any way of allowing it to fold when not in use, or is it always needed to be in use to trickle charge as you go* ?.
*Sorry, I haven't read the entire thread, so may have missed the part on how long in use it takes to supply enough of a charge to replenish the batteries enough for the next days leg.
Andy, sorry for the late reply. Somehow, working on a small phone screen without my glasses I had inadvertently marked you as ignore. Only saw your post when back home on a larger screen and not logged in!
The answer is that it is a balance between battery capacity, panel power and the trip details of weather, distance per day, hilliness and so on.
My setup is a version 1, just how things fell together rather than a considered in detail conscious design. It has a particularly small effective battery capacity of only about 300Wh, which means I need to live fairly closely to within what I am generating moment by moment. That's 30 miles at my typical 10Wh per mile, and I have just completed 470 miles without any external charging. The panel size of 330W is roughly what I have read of other solo solar bikes using, and has proved itself sufficient to work with the small battery in all conditions so far encountered.
Riding with the panel area fully deployed is an essential part of long distance infinite range touring, because the middle six hours of the solar day are the most powerful sunshine. There is useful charging at the ends of the day especially with the trailer tilted to the sun, but it can't replace those middle hours.
A bigger battery would make the greyer days less stressful, and might allow two panels instead of three do the job.
Folding, or more likely stacking panels, would be useful for going by train or plane, but that is not on my agenda. Also for a compact setup for riding into wilder places. Having said that, unless the trailer was made a one wheeler, a small top would not make much difference to the way this Burley based one rides. It is remarkable given the roughly 1 inch of suspension travel!
In full sun, at rest with the trailer tilted I have seen 8amps or slightly more occasionally, at 38 to 41 V, so these nominally 330W panels get pretty close to full rated output. Thus if my 300 usable Wh are empty, an hour of good sun is enough to fill them up again! But the key is to deplete slowly, in parallel with panel output, to stretch those 300Wh over enough miles or hours to get to the next sunny rest stop or evening. The numbers I posted yesterday show that approach in detail.
A different type of expedition could take a very different approach. For example, going into the wilds to camp and climb for a few days, having a battery just about big enough to get there but not back, a single panel, which would mount fairly well on a standard size of kiddies or cargo trailer, maybe with a slightly extended towbar, and a charge controller is all that is needed to charge at camp to come home. 3kg of weight, 1.2m by 0.6m area. Assuming a generic type ebike system.
cyclebuddy
1,678
784
Beds & Norfolk
I for one have thoroughly enjoyed following your "experimental journey" and travel vlog, beautifully documented with photos of the kit, route, and challenges you've encountered. I've certainly learned a lot (the data/power gained/usage patterns are interesting) so thank-you for that, and I await your changes based on your learnings to create V2 of the solar rig and the next tour. Brilliantly done! Thank you!
matthewslack
2,594
1,671
You're welcome, I've enjoyed doing it and georgehenry's writings inspired me to make it a bit more than just words and energy numbers.
The final tally was a bit less than last night's estimate, 1458km round trip. Then another 25km in multiple shopping trips to restock my empty kitchen.
And I am still just showing a positive COVID test, so can't actually go back to work yet.
The last camp:
And welcome committee:
Even after all the shopping runs, which were without the trailer, the Shimano battery had half a bar left, and plenty in the solar battery, so this was the first trip without the need for any external charging.
I have a plan involving an old Shimano charger to overcome this limitation by bypassing it's AC stage and feeding it 42V DC instead. But that is for one of my tomorrows.
I'll be back with some data files and the next trip in due course. If the weather holds, it won't be long!
Reactions: Leeroy
Leeroy
21
The last camp:
You've done a great job on that Matthew, some amazing scenery too!
