The small rear xiongda motor with controller/lcd/packaging, weighing under 2kg. It's tiny.
It is a freewheel motor 135mm wide dropout axle width. It will take an 8 speed freewheel with 3or4mm spacer washers on the freewheel side which would maybe need taking into consideration when measuring for spoke lengths.
I chose to fit this to my wifes leasure bike since it's wheel rim has 36holes and I could also re-use the 6spd freewheel and tyre too.
I am still trying ideas about controller/battery fitting but trying this for now. Spot the motor-
