Sevenoaks Electric Bikes
17,264
If I'm ever in Southend I'll buy you a coffee and you can educate me!
Did you mean Sevenoaks? I am on the other side of the Thames.
Az.
2,170
983
Plymouth
you would think they would be the people best capable of judging such things.
Would you? For starters this guy was saying CYC X1 Stealth has something like street legal mode. No, it is not a legal motor. It also costs a fortune unfortunately.
It is also a very unfair comparison. One motor is rated 250W, another is 1500W. It doesn't take a rocket scientist to determine which will perform better.
Reactions: Nealh and robert44
portals
780
230
I'd like to see a Woosh vid of someone riding the 2 same bikes mentioned above (mid vs hub), and see which performs best up hills with same 250W power and battery?
17,264
a couple of hundreds metres from my shop is Piers Hill. It's not very high, about 50m-70m elevation but it's a short, straight up the cliff climb. Most hub motors will struggle without the rider's help.
portals
780
230
So I could sail up that hill easily at 15mph with my rear hub even with a stop then start. It's not wreckless to accelerate away from say lights and up a steep hill (with throttle to get you started then pedalling and moving up thro' PAS from 1->5 in a few seconds), this is the experience I hoped for when looking in to ebikes, I wouldn't care these days if it's limited to 15.5mph but I want the power to get up hills, no messing about, that's my main requirement and probably many others who are getting 'older'...!
2,835
portals
780
230
Thanks for the link, I didn't read all the posts (crikey 4 pages+), but from what I've gathered disabled people are feeling bumped by the lack of power available to them if they end up having to stop on a hill/gradient of any significance with the anaemic currently legal motors most of them have.
Maybe they need to look in to the blue badge system and if you have one are given grace to say up to 750W/1000W motor on your ebike/trike etc....which granted might introduce other problems...for example when the grandkids visit and they want a shot....
30,820
No need to look since bicycle based 1000 watt machines are already permitted. They are limited to the identical 15.5 mph and are L1e-A mopeds, informally known as Low Powered Mopeds. A minimum group Q driving licence and third party insurance are necessary, but they are necessary for any disabled person using a motor vehicle, so there couldn't be an exemption.
3,366
When I remember to change to a very low gear, hill starts at traffic lights are no problem for my 20" wheeled BBS01B mid drive conversion, with the controller limited to 15A... 52T>32T sometimes, which is my lowest gear. When the throttle was still on the bike, I'd simply activate it while slowing down and not pedalling, shifting down through the gears before stopping, the gear sensor keeping the motor switched off as it did so between gear changes. No crunches even when rapidly moving three or four gears down, or the whole 7 changes (my bike has 8 gears in total).
I doubt I'd be able to do the same exact hill same start with a rear hub motor using the same battery and a 15A controller. And certainly not while dragging a 90kg bike trailer, which is no problem for my 250W mid-drive conversion.
3,366
I agree with that. Especially important is the ability to start on a steep hill. See Chris Juden's thread on Cycle UK forum. https://forum.cyclinguk.org/viewtopic.php?t=157613
After removing my throttle - when stopped on a high gear, I tried starting on hills using walk assist while staying on the bike, but unfortunately there's a pause before walk assist starts, and there's a rather too long motor cutoff period after you release the walk assist button, during which time pedal assist won't start... and if you haven't changed down gears by then (unlikely, 6km/h and slowing uphill), you're stuck trying to pedal without assistance on too high a gear, or on a low gear you can't move. Come on the legal throttle law change!
portals
780
230
Interesting, is having a blue badge a requirement to ride these bikes, cannot find any decent info.
Anyway, not having a blue badge, if a 500W kit became available that would get up hills with stop/start then probably I'd get one and sell current kit.
Until then I don't really think a a lot of them are fit for purpose if they cannot reliably get a hill with stop/start if it's a busy hill with traffic and lights. Nobody would buy a car that cannot get up steep hills so why should I have to put up with it on an ebike?
30,820
No blue badge needed, L1 is a normal EU motor vehicle class, specified in the Two and Three Wheeled Motor Vehicle Type Approval Regulation 168/2013 . That also contains the exemption for EPACs from being considered motor vehicles. This EU regulation is wholly incorporated into UK law.
Since it is bedtime reading for a few years, here's the extracts you need.
The EAPC exemption and walk alongside related exemptions:
Scope
2. This Regulation does not apply to the following vehicles:
(a)vehicles with a maximum design speed not exceeding 6 km/h;
(c)vehicles exclusively intended for pedestrian control;
(h)pedal cycles with pedal assistance which are equipped with an auxiliary electric motor having a maximum continuous rated power of less than or equal to 250 W, where the output of the motor is cut off when the cyclist stops pedalling and is otherwise progressively reduced and finally cut off before the vehicle speed reaches 25 km/h;
The motor vehicle categories:
Article 4
1. L-category vehicles comprise powered two-, three- and four-wheel vehicles as categorised in this Article and Annex I, including powered cycles, two- and three-wheel mopeds, two- and three-wheel motorcycles, motorcycles with side-cars, light and heavy on-road quads, and light and heavy quadri-mobiles.
2. For the purposes of this Regulation, the following vehicle categories and subcategories shall apply, as described in Annex I:
(a)category L1e vehicle (light two-wheel powered vehicle), sub-categorised into:
(i)L1e-A vehicle (powered cycle);
(ii)L1e-B vehicle (two-wheel moped);
L1e-A is the one I mentioned, 1000 watts limited to 15.5 mph
L1e-B includes the S class speed pedelecs.
Reactions: portals
Wisper Bikes
6,315
2,279
70
Sevenoaks Kent
The Sevenoaks Bike Festival is now a "thing!"
It will take place in the `Vine Gardens' Sevenoaks on 21st September from 10.00 to 16.00 and will be the precursor to a larger event next spring/early summer. when Sevenoaks Town Council will be shutting some roads to create a "real life" test track.
The event is completely free for anyone to visit. I am fed up with event companies charging a fortune to people to come try or even buy a bike!
IN the September event will have a limited test track around the Gardens, but if anyone would like a longer test ride please let me know.
www.sevenoaksbikefestival.com
All the best, David
59138
Reactions: Nealh
8,755
Excellent David and an innitive I hope pays off for your company, well done to 7oaks Town for arranging the future road closures as well at the next event.
I would love to pop along David ( not too far from me) and say 'Hello', even to try a few bikes out , alas I will or should be in hospital recovering from my major surgery taking place that week.
Next spring /early simmer though may be more suitable and hopefully I'm back on my feet , maybe might even be able to arrange a meet up with a few other forum faces as well.
3,898
It was great when we had the Redbridge event, so you've made me very happy to create an event in Sevenoaks. I probably won't manage the Seprember one, but I'd be up for anything in Spring. It would be nice to meet up with forum members as well, like we used to.
Reactions: Wisper Bikes
