Schottky Diode Parallel Pack Adaptor
awol
1,216
374
The schottky diodes I ordered were 100v 40a. I've folded the middle legs around the back of the heatsinks and screwed them together through the diode holes then soldered the discharge pos to the aluminium heatsinks which was a seperate project all in itself.
Is there a way to test this before connecting up?
WheezyRider
1,690
938
Safest way to test is to get a couple of old dry cell batteries with different voltages, one old, one new (a couple of PP3 9V cells are good for this as you can crock clip leads from the terminals onto the XT60s). Connect them up to the legs in the Y. Put them both on together, you should see the voltage of the highest output cell at the output of the Y. Disconnect the higher output cell and you should see the voltage of the lower output cell at the output of the Y.
Then, put a cell on one arm and test to see that there is no voltage seen at the arm where the other battery would be. Repeat on the opposite arm.
Check for shorts where there shouldn't be and you should be good to go!
Before use on the bike, connect the e-bike battery packs to the Y without the output connected to the controller, just to check you have all in order with a voltmeter before you connect it to the controller.
Reactions: Bikes4two and awol
alban
110
Great write up and pics. Did this some years ago joining a LiFePO to a LiPO pack. and has worked for me. But can't recall how on earth I did it so thanks for the heads up!
awol
1,216
374
These look interesting, "smart" diodes:
They have a voltage drop of only 26mV!
They only go up to 30V at 15A, so you would probably have to put several in a series parallel arrangement for an e-bike, but they have the potential to be highly efficient for this sort of application. It will be interesting to see what they are like at coping with inrush currents.
Could this be a similar thing ? This looks quite a complicated bit of electronics to do what you've achieved with a single diode.
Also there is a resistor on the board, could that be one of those precharge resistors?
3,993
You'd need two of them - one for each battery. It's basically a powered diode with a very low resistance, so no significant power loss or voltage drop. You need a ground to power it. I haven't studied one of those, but I'd guess that the other components are to cut down and regulate the supply to it.
Reactions: awol and Bikes4two
WheezyRider
1,690
938
As vfr said, you'd need to have two of these, but they are essentially what I was talking about in my post #20. They use a tiny amount of power to drive the "diode", without causing a significant voltage drop.
However, looks like people have already thought about this concept for electric bikes:
This one seems to allow you to charge and discharge two batteries together, with minimal voltage drop power loss.
  • Useful
Reactions: crwro
WheezyRider
1,690
938
Hi Wheezy - I’m coming to this party late, but did you test out the ideal diode setup?
Hi Yak,
Sorry not been on the forum so much these days. Yes, they work really well. However, you do need to connect the IC circuit to ground, which is not obvious and there are no instructions from eBay or the suppliers. If you do not do this, they act as a standard diode and get very hot.
WheezyRider
1,690
938
This is the pin that needs grounding:
45316
These ideal diodes are pretty good, but there are even better ones out there which use a MOSFET with an even lower RDS on and are even more efficient.
WheezyRider
1,690
938
Here is the circuit diagram for the ideal diode set up:
45322
The wire from the ideal diode to ground does not need to be thick wire like anode/cathode and battery negative wire. It just has to carry a tiny current to allow the ideal diode to function properly.
Reactions: Yak and Bikes4two
Dan7
14
What do you think about using this connector and Schottky Diode?
48274
Sudoo Solar PV Blocking Diode Schottky Barrier Rectifier Bypass MC4 Compatible Anti Reverse 1000V 20A (1) https://amzn.eu/d/9okhWiq
Made for solar panels so its waterproof.
Might have to change Diode to a 30amp.
I've had no luck in finding empty ones to use your own Diode.
My controller compartment can't fit anything else in it so looking for something neat externally and no chance on shorting on anything.
Instead of xt60 connectors you can get just the male or female connectors of these for joining
Dan7
14
Looks to be .46v
Not great but they look easy to replace.
Just ordered 2, will see what I get :)
WheezyRider
1,690
938
Parallel splitters like these are super cheap to
Good thinking, but I think maybe a bit bulky and heavy compared to XT60 connectors.
If the diode is encapsulated inside a connector, there is also the issue of heat build up. May not be a problem if the heavy duty wire acts as a heat sink though.
Dan7
14
The diodes arrived.
They are very light and not as big as I thought.
Just waiting for the rest of the adapters to arrive.
The adapters are rated for 30a and diodes 20 but look easy to swap so I would imagine perfect for most 24/36v setups.
I like the idea of having a proper made to purpose thing than making my own and having to try and find something to put it in so it doesn't short.
Batteries are scary :)
4830748308
