Unlikely. Most controllers have to sense zero throttle before they'll allow power, so you can't start up with a broken or jammed throttle.Or the ground on the throttle isn't connected?
I think you're getting mixed up between brushless (three phase) and brushed (single phase).Sorry I thought" Type 3: Hall sensor and sensorless compatiable, without 3-speed switch, learning itself by a switch. LVC=30/31V(36V) 20/21 V(24V)." meant it'd work without hall sensors. Unless it's just badly worded.
Arr didn't know that; I sometimes check motors/controllers by just tapping the +5 and signal from the controller together (no ground) and they have always run wot until I disconnect?Unlikely. Most controllers have to sense zero throttle before they'll allow power, so you can't start up with a broken or jammed throttle
