S-Cross Central Display Oxygen ebike.
8,616
8,616
Eventually you may see an error code but if it keeps switching off every 5 mins riding will become tedious.
Reactions: Leedspete
Leedspete
80
7
In theory can I replace the rear motor with any other motor?
As long as it has the same connectors as on my ebike I would think it’s ok or not
8,616
Yes.
Most use the 9 pin Julet waterproof connector which use a std pin layout.
It is a bit extreme as a new hub and then the cost of getting it laced/trued up Vs a rather simple speed sensor fix that will only need a bit of time and about £15 to repair.
Leedspete
80
7
Yes.
Just in case. Lol
Leedspete
80
7
Just tried to get motor open and I couldnt. Feel like this is a lost cause. Someone was coming today but has let me down.
8,616
What did you try to open it ?
8,616
On the brake side one has to undo the inner axle nut so that the motor unit with axle can slide out from the RHS.
8,616
The cover comes off with the motor and axle attached, the magnet housing will be on the peripheral edge of the inner side of the cover.
Leedspete
80
7
Ok. But I can’t actually get the screws out. May be the screw drivers I am using could be the problem.
Leedspete
80
7
Would this work on my bike? Bafang E-Bike Motorised Rear Wheel 700c Silver with Tyre 36V 250W
8,616
If the motor cable connection is the same then yes.
