Thanks - very illuminating.
Alex you really must try and shape up here, this kind of derisory and frankly snide talk of Tonaros will simply not be tolerated here. Clearly you have tried none of the Tonaro range nor it seems, have a technical background, but rely instead on the ill considered ravings of a sadly diminished journalist.
I would put my Tonaro Bighit up against any Bosch drive in the country for climbing ability and they are pretty good on range too.
The Bighit has a seatpost rack. Point is this type of rack would not stand up to being loaded with heavy loads of gear or goods on the back of the bike... which is what I bought my crank drive bike for, not offroading. I have clocked many makes of bike but did not even realize Tonaro was a make and just thought it was model and that is presumably quite clear from my post. If you choose to "read in" derogatory remarks where there are simply innocent statements I can only put that down to the fact that looking at subsequent posts the bike has come in for some flack - which I have also never seen.
Your defensive-aggressive ramblings I will put down to sensitivity over previous feuds on the topic and am happy to ignore as irrational outbursts. I am starting to get a wee bit worried about your state of mind, hech. I prescribe a long bike tour to mellow out a bit
What on earth makes you say that ?
The rear rack is extremely strong and capable of carrying a more than decent load....mind you.....I dont know what sort of chain you travel around with
As for claimed range.....mine easily does the claimed range on mixed terrain, (and Im no cheryl cole ) battery is the same now as it was 16 months ago....so far so good.
All in all a extremely suitable and functional bike for anyone
Have you actually tried one ?
I find thats usually a good measure of whether a bike is suitable for anyone
No seatpost-mounted rack is likely to tolerate my rear loads. As you'll see from Geebee's post and my response to it, I didn't realize Tonaro was a make of bike having only 'clocked' the Bighit previously and therefore assumed you had one of those. Obviously I looked it up when Geebee pointed things out. However, I still would not want my battery in the rack area. Whether on a hub-drive or a crank. It loads weight to an area I'd always want clear to load with other weight.
My chain is very heavy with a closed-shackle padlock. Would be acceptable for motorbike. No point taking chances when you rely on bike for primary transport even when left for short periods. It lives in my rack bag.
I can't comment on range but I do know what a 36v 15Ah 540wh battery will give you (70+ miles easy in average conditions with a 250W rated Impulse) and that is what I was looking for in my primary travelling bike. If you don't travel to and from an office (I work from home) and want to tour via wild remote country places rather than pub stops or shops etc. to recharge, having enough capacity to get you where you are going and home again on one battery is more important. Granted most people would rather stop off at the pub for a beer and charge their battery there - but I would rather spend that time in the countryside with my lunch and liquid supplies in my panniers. Each to their own
The only way to properly try one would be to have it on approval, take it on a long trip to see its real battery capacity and ride it in a variety of real-life conditions. Since few suppliers will allow that (although Kalkhoff have done recently) you have to go (to some extent at least) by looking at specs, design and functionality for the use
you intend to put the bike to. Regardless of whether the bike can be easily derestricted for higher assist speed, the point is that if range is a key priority for someone, a 540Wh battery with an efficient motor is considerably more likely to fit the bill than the Tonaros and if that's more of a priority then range wins. I may be new to eBikes, but even I managed to work that one out pretty early on.
