There are several ways.
The kit comes with a barb connector, so you can just push a short length of hydraulic hose from the easiest direction, connect the barb, and pull back through.
You could use an electricians cable routing rod.
A length of wire threaded through, and just tape the hose to it.
Attach the hose and a piece of wire, to the existing Bosch wiring and pull it back through, which would leave the hose and wire pulled through, you can then attach the Bosch cable to the piece of wire, and just pull it back down again. It sounds more complicated that it actually is.
