Review of Argos £245 E-move folder
3,411
This is a hub motor Guerney, so it wasn't a gearing issue.
Get fat fast and tow a trailer?
It was really a momentary issue caused by a water main being opened and gushing onto the road. At the time it happened, there was an inch or more of water on the road, and it was not until a later passage over the place, that I noticed there was a steel hatch covering over an underground service, in exactly the place I slipped.
It is easy to see what happened. Rider comes slowly onto road from mud path, and turns on flooded surface with harsh take up speed control e-bike, right on the flooded, steel hatch cover. Power comes on hard, wheel spins out, rider is turning, back end steps out, geriatric rider falls off cursing, picks himself up and rides off red faced with embarrassment....
As long as it doesn't happen on wet tarmac.
8,843
Any bike when powered on over a wet metal cover would spin out on the rear, it isn't just a hub issue. Oner reason why I stay clear of them and never apply my brakes when on/over them
G
Ghost1951
Yes. I agree. It was hidden under a running flood from an open water main, gushing out of a stand pipe, at least an inch deep, and just as I came around a corner out of a rough track onto the flooded roadway, the rather fierce controller kicked in.... Ooops.
Garry Hallam
104
10
I just picked one of these up 2nd hand but it is as new. Barely ridden at all. I was quite impressed with it for a cheap folder.
The brakes are are made by clarkes and seem decent quality but the steerer and handlebars seem pretty naff and fold between the frame. I much prefer them folding the oppsite way. Better stem and riser can be had for about £25 so will be my first mod.
The seat post slides directly into the steel tube and hard to lock up properly. I will probably use the lathe to turn a nylon bush to take a smaller stem if I can source one.
Reactions: Peter.Bridge
Garry Hallam
104
10
The display controller is playing up on my bike. I will check connections but It will not power off sometimes without switching off at the battery. Anybody else experienced this?
Reactions: thelarkbox
4,226
Looks like I will need a new display. Do you know what type they are?
No you don't. I figured it out for you today. You're pressing the button too long. It only switches off with a short press. You need a long press to switch on, but a short one to switch off. If you press it too long to switch off, nothing happens.
Reactions: Garry Hallam
Garry Hallam
104
10
Thanks, I came to that conclusion after talking to the seller on the Sunday Market. But I have not tried it yet. I do hope you are right though. I'm an idiot :rolleyes:
