That bloody cheap? Wow! Thanks for the ratio quantities too.£3 gets you a useable soldering iron on Ebay - a lot cheaper than a crimping tool. You want 60/40 tin/lead solder.
I haven't ordered anything yet, but I think It might be worth just disgerading the crimping tool and soldering instead. This way I can use the XT60 connectors rather than the Anderson Powerpoles.
The battery I'd be buying is connected with Anderson Powerpoles, however, It shouldn't been too hard to remove this and apply an XT60 connector correct? As long as I treat the battery wire with great care I should be safe I'm assuming. (I.e. Soldering only one wire at a time)
