The king is not changeable, pressing the 2 buttons only gives you the option of changing the voltage from 24v to 36v. On mine anyway.Hi Has the Sport fitted with a King LCD display if so it may be programable yo 22 mph
Frank
Frank
Do you mean different controllers affect how fast the bike can go?Hi It may be worth a telephone call to the guys in the add below to se how fast there controller is I see the sell a 3 speed switch for 24 or 36 volt
ELECTRIC BIKE CONTROLLER 250W 24V 10A- SENSORLESS & HALL SENSOR COMPATIBLE | eBay
ELECTRIC BIKE E BIKE 3 SPEED SWITCH 24V 36 V E BIKE CONTROLLERS 0.8 METRE LEAD | eBay
I think you could be right.Since this thread started, I've seen another controller like Spikey's. The big white lead is a programming lead, which is a bit worrying. Unlikely, but it might mean that the speed limit is programmed into the software, and it could use a hall signal to check the speed. We'll know when the booster battery is finished.
Well unless you can find any free cells. I found a local laptop repair shop who were having to give me for free out of dead laptops.The Ku65 can handle 12S lipos that go up to 50v, but a 48v battery goes up to 54v, which is over the 53v limit of the capacitors. Some people have done it and got away with it, but it's risky.
I'd keep the booster battery on ice until you get a new controller.
If that's the case and a 36v 8fun controller is not so limited (we know from other members )When you get this cutting in and out at 15 mph, it's very likely to be caused by a limiter, which can't be solved with a booster pack.
