Esay answer Gubbins. Like all car makers they used the old way of measuring range (mpg in most cars) and it resulted in hopelessly optimistic range, just like the mpg. Under that old standard my Leaf should have up to 230 miles range, no chance.
However the new standard now being used by all makers is WLTP (Worldwide Harmonised Light Vehicle Test Procedure) and that is much better.
For my car WLTP forecasts 168 miles.
I haven't had the car long but I've given it two range tests. On the first I was driving it as hard as I could, but that limited by south east traffic conditions. However I managed some 80 mph overtakes and a flat out climb from the low level of the Weald to the top of the North Downs during the driving. I covered 104 miles and there was 30% left in the battery. I discounted that 30% by the amount that the 104 miles from 70% indicated and the end total was a range of 152 miles. Bear in mind I didn't use the Eco setting at any time and wasn't trying for regeneration, only for performance, so that 152 miles compared favourably with the 168 indicated for normal driving.
The second range test was entirely done with normal driving but again never using Eco. On that, having gained confidence with what it could do, I ran the battery very low in the final stages close to home. The "charge now" warning came up witn 11% left and 142.4 miles covered, but I ignored that and carried on down to 3% and 155.2 miles covered. The 3% represents 4.8 miles of 160 and I used that to go the last bit home including climbing my 14% hill to the garage. So I'd covered exactly 160 miles with a tiny bit left in the battery.
I think that validates WLTP's 168 mile claim, and I could easily exceed that by using Eco and it's higher regeneration.
I've also been investigating the linearity of the new Leaf's "Mileage left" indications. When first fully charged from the Pod Point home charger it can read anything from 170 to 174 miles. However, for the first 30 or so miles the indicated range reduces at anything up to double the actual miles covered, so the non-linearity is all at the top end when there's plenty left, very sensible.
At the bottom end when there's not much left it's very accurate with my driving, delivering exactly what's promised.
