Depends on the steepness of your hills and your own cycling ability Bob. If your's aren't the steepest around, an 18 or 19 tooth is a fairly safe bet, but it's usually best to use a bike first and determine from that what you want.
To tell what you need once you've got the bike and ride it in your area:
If you find you don't need 1st gear, fit a 20 tooth.
If you find you don't need 1st or 2nd, fit an 18 tooth.
and so on.
50cycles will do it pre-delivery if wished as quoted above.
and so on.
