That's good, then. All your cells are healthy, so you have a connection problem somewhere or a faulty BMS, or a faulty temperature sensor. I will have one of these batteries in a couple of days, thanks to Cyclezee. I will then be able to show you where to check further. The photos that I've seen are not enough to show me anything useful. While you're waiting, you could plug the connector back in, reconnect the blue wire, loosely put the box back together (no screws), and try it in your bike. It could be that the blue wire was loose, and sometimes the BMS comes back to life when you re-plug the multipin connector.
The blue wire must have a partner somewhere. It'll be wire the same size and with a barrel connector to receive the bullet on the blue wire. It should be easy to find.
