It's pretty standard during acceleration from standstill on full throttle on mine. Also on steep climbs >15% 'flat-out' on full throttle it'll put that out continuous round the 13-17mph range for a considerable time. I don't run it continuously like that on throttle-only (in fact hardly ever ride the bike throttle-only).In use, you rarely see that sort of current. You have to be going fairly slowly at maximum throttle.
It does make me think, however, that a 48V 25A system wouldn't that give much discernable improvement than is already being achieved, apart from maybe a bit more help on a throttle-only climb or to compensate additional weight ? The new variant BMS controllers with displays like the S12S look to be running considerably lower amps at 36V (22A) so presumably the power differential will be much more noticeable with these ?
Customer comments left on BMS website along with CA and other measured figures also seem to bear out that the controller will pull up to 30 amps given enough battery : http://www.bmsbattery.com/controller/364-universal-brushless-hub-motor-controller.html
