Punctures !!!!
mw1
146
43
58
Hull, E.Yorks
I wouldn't use those strips that go inside the tyres. they cause more punctures than they save.
What problems have you had with them D8veh, and others?
The reason I ask is because I recently came across a pair for nothing & have fitted them in 2 of my rear motor ebikes, though haven't yet done enough miles on either to properly evaluate them. Time will tell...
Regards, Mark
danielrlee
1,396
725
Westbury, Wiltshire
torquetech.co.uk
Regards, Mark
I've had a positive, albeit rather limited experience with tyre inserts.
I used to experience a puncture every couple of weeks, but since fitting liners to my main ride about 18 months ago, have only had one. The puncture was caused by a meaty 2" thorn that penetrated right through the liner.
When I fitted the tyre liners, I used an abrasive to taper the ends as to minimise their profile and the wear effect on the inner tube as others have experienced. I don't know how effective this measure was, but I've been happy with my puncture rate since fitting them.
  • Useful
Reactions: mw1
mw1
146
43
58
Hull, E.Yorks
Thanks for your reply Dan. 18 months is long enough to make an informed opinion :)
Useful tip re tapering the ends, so will have a look at doing that before I do many more miles.
Cheers, Mark :)
