OK for tubeless tyres, but doesn't seem to work for tubed ones, and, like Flecc Says, it rubs salt into your wounds when you see what a mess it makes. Maybe it works sometimes because, of course, you only know when it doesn't work. The best thing by far is Schwalbe Marathon Plus tyres if you don't want punctures, but they're not much good off-road.That's a good idea, will try this next time.
As a matter of interest, has anyone any experience with that green slime stuff?
Problem is my current tyres are 26 x 3.0. Not the easiest size to get for any make of tyre. So I'm stuck with using inner tubes and I like the wide 3.0 tyres. It sounds like my best option is to carry a repair kit and try a road side repair as described by flecc if (when) I ever get a puncture.OK for tubeless tyres, but doesn't seem to work for tubed ones, and, like Flecc Says, it rubs salt into your wounds when you see what a mess it makes. Maybe it works sometimes because, of course, you only know when it doesn't work. The best thing by far is Schwalbe Marathon Plus tyres if you don't want punctures, but they're not much good off-road.
Everything has advantages and disadvantages.Problem is my current tyres are 26 x 3.0. Not the easiest size to get for any make of tyre. So I'm stuck with using inner tubes and I like the wide 3.0 tyres. It sounds like my best option is to carry a repair kit and try a road side repair as described by flecc if (when) I ever get a puncture.
Also an MTB version, not quite 3 inches though...There is an off road version with level 7 protection:
Marathon Plus Tour Road Bike Tire - HS 404 | Schwalbe Tires
The Marathon Plus Flatless version is a heavy-duty trekking tread for asphalt, or off-road allows this versatile tire to always feel at home, whether in everyday use, or on long tours.www.schwalbetires.com
Do you really need 3 inch tyres?
Tell that to the freshly cut hawthorn twigs on the tow path!But with decent tyres, you should very rarely get a puncture.
Yes, the only puncture I've had in the last 14 years with was due to a thorn on a 28 wide Durano Plus tyre. Thorns are worse than broken glass or even nails.Tell that to the freshly cut hawthorn twigs on the tow path!
Couldnt upturn the bike, it's bristling with fone holder / electric bell / gps data gauge.Unhappy experience, but avoidable:
1) Don't remove the rear wheel, just unlatch the brake cable at the noodle.
2) Take the tube out on the non chain side and put a little air into it.
3) Locate the puncure and repair the tube, it's easy to ease it around between the wheel and frame tubes.
4) Replace, pump it up and relatch the brake cable.
That's how we repaired almost all bike punctures in the trade.
Also buy yourself a decent pump to carry with you. As you found, that one is useless.
I even replace tube and tyres without taking out the rear wheel, though it needs care and some skill to expand the frame and pass the tube or tyre through with the other hand:
That lukewarm review is from 3 years ago. The tyres are pricey at £90 a pair. https://www.geckorubber.co.uk/how-to-buy---fit.htmlThese with a suspension seat post perhaps?... solid tyre review or https://ebiketips.road.cc/content/news/first-ride-gecko-rubber-solid-tyres-630
Fit bar ends either outboard or inboard as I recommended and illustrated and you could turn it over.Couldnt upturn the bike, it's bristling with fone holder / electric bell / gps data gauge.
That is simply not true, patching done properly will withstand any pressure. The problem is that so few cyclists, however experienced, have a clue how to use patches, something we were always explaining to them when I was in the trade.Tyres need 85psi - told by many avid bikers that repairing with a patch is not clever and often fails at this pressure.
All punctures, no. But this Marathon Plus one from Schwalbe prevents nearly all:Surely there isn't a tyre that can protect against all punctures???
I was going to say exactly the same thing until Flecc beat me to it. It never ceases to amaze me how much crap is floating around to try and prevent people from using simple solutions.That is simply not true, patching done properly will withstand any pressure. The problem is that so few cyclists, however experienced, have a clue how to use patches, something we were always explaining to them when I was in the trade.
