That's the issue there I believe. The battery voltage has dropped below the low voltage cuttoff (which is likely 30v ish)Good morning. I have tested the battery as described above and it is coming out with a reading of -26.7 and falling and getting nothing at the throttle connector,
When you plug the charger in does the light just stay green ? Presumably so in which case the voltage has dropped too far down for the BMS
Is it still under warranty ? If not there are options , it may well be possible to save/fix
