UK Sex Education Class Promoted ‘Choking’ to Teenagers
We have permitted the porn industry to transform our society, and to shape the sexual desires of an entire generation. If we want this to stop, we should cut this poison off at the source.
Last April, I made 474.8 units. The one before was 368.3. This April so far, it's 620.6 and I should make another 30 tomorrow. There must be something seriously wrong with your system. I know you don't have as much as me (mine is supposed to be 5kw, but most in April is 4kw), but it shouldn't be less than last April because we've had 15 days where there was full sunshine for at least 6 hours, and only one day like that in last April.from April last year to this one im 51.8kw down this year this month![]()
Tomorrow should be sunny all day again. At 12 o'clock midday, have a look at how many KW you're generating.the inverter does not have a ct clamp connected to it but it is the same setup as last year and a 3kw solax inverter.
may last year i generated more than we imported so see end of month and had them cleaned.
147.8 this year
208.2 last year
Older panels used to be 300W+, so let's say you have a theoretical max of 2400w. 1125w seems too low. Can you get a solar company to check your system? It could be that a wire's detatched or something. Do you own your house yet and do you own the panels?peak today was 10.52 and 1.125kw and have 8 panels but was fitted 2015
I listened to a business man on the radio a few months back talking about how he wanted to build charge facilities on a motorway somewhere in the UK and was told by national grid that they could not supply the required electric power to run them for ten years. ABSOLUTELY BONKERS!!!
In Europe, charging stations are often built next to wind or solar farm and connected to the farm directly plus backup battery. Savings for customers are around 25%, instead of 60 cents per kWH on high speed charging (100+kw), customers pay 45 cents.What is its proximity to the grid for rerouting power ?
