Power cable
Nixtoo
103
47
I need to extend a power cable from the battery. Can anyone recommend what sort of cable I should get? It’s a 250w36V system. The controller is marked 17a. Thanks
8,839
14 awg silicone will be fine.
8,839
Nixtoo
103
47
What do you put over the two cables? They would look neater with an outer cable in black?
8,839
I don't usually other too much, have used spiral wrap before but it looks a bit unsightly.
3,410
I use this stuff; I like that zipties securing wires to the frame covered with it, don't apply as much direct pressure. The edges can be tidied using a flame:
Reactions: Nealh
