Yay Hi Michelle and thank you! Why not start a thread & post a pic? All these kits seem pretty universal so am sure it'll be doableI really enjoyed your lock down project it turned out really well good on you. And you got me thinking if i should convert a bike i have in my garage, its a Marin attack trail i'm not sure if it would be the best to convert though
Interesting. Multimeter shows 49.2v so would that be about 80% charged?Maybe the battery meter isn't calculating correctly. I think I'd check the battery with a voltmeter and test how far you can go before segments disappear.
I'd say less. 48v is half way. 51 v is 75% and 45v is 25%, approximately. 49.5v would be 62.5%.Interesting. Multimeter shows 49.2v so would that be about 80% charged?
Do one long ride to figure out what happens to the display. Take a voltmeter to keep an eye on the battery, then you'll know for the future what to expect.May keep my mileage around 50-60 miles then or at least check it again with the multimeter at 50 miles.
Worra faff!
Had a similar situation to you in that the display showed full battery for a suspiciously long time time before dropping any bars. Then the powerpack leds finally went down by one and and things started tracking. I put it down to me supplying too many watts myself. Have committed to being lazier and letting the drive do more work when the Mundo's up and running, which it'll have to because it's a bloody tank!It's getting stranger now. Have done 39 miles - the LCD still shows full which I am now taking as unreliable, but additionally (& separately really!) the row of LEDs on the battery casing are still fully lit. On the 1st use cycle these dropped off roughly in line with the LCD displays battery gauge...am regretting not checking the battery with a multimeter when it was new out of the box.
Those charge indicators are pretty vague TBH. It's worth wiring an inline voltmeter between the battery and the motor if you want a more accurate picture. Based on the voltage/ percentage charge figures previously posted, you'll then get an idea of how much range you've actually got.It's getting stranger now. Have done 39 miles - the LCD still shows full which I am now taking as unreliable, but additionally (& separately really!) the row of LEDs on the battery casing are still fully lit. On the 1st use cycle these dropped off roughly in line with the LCD displays battery gauge...am regretting not checking the battery with a multimeter when it was new out of the box.
Will be an awesome tank tho!Had a similar situation to you in that the display showed full battery for a suspiciously long time time before dropping any bars. Then the powerpack leds finally went down by one and and things started tracking. I put it down to me supplying too many watts myself. Have committed to being lazier and letting the drive do more work when the Mundo's up and running, which it'll have to because it's a bloody tank!
Okay thank you. Voltmeter sounds a good idea.Those charge indicators are pretty vague TBH. It's worth wiring an inline voltmeter between the battery and the motor if you want a more accurate picture. Based on the voltage/ percentage charge figures previously posted, you'll then get an idea of how much range you've actually got.
My 48v system is fully charged at 54.4v and it's totally gutless at 45v (although it hasn't actually hit the LVC)...
Brilliant way to spend an evening. And the light was amazing late yesterday afternoon/early evening with that whole summer-into-autumn soft focus thing going on. And you're spot on - hills suddenly become way more interesting when your electric stoker does the hard work .Quick update: bike is doing amazing.
The battery at 45.8v is getting ready for it's 3rd charge but am on nights all week so will wait until the weekend - charging before it's next use.
Sunday evening was spent alleviating some stress with a 12 mile loop taking in Peak Forest Canal towpath & a 1 in 5 ascent to pass over a local hill for home. That last bit was a revelation. It's magic!
Awesome innit!...pick the right gear, crank up the assistance and sit back and enjoy the view.
