Pimp my HAIBIKE! What have you already changed on the bike?
6,596
6,596
id rather not have it at all tbh or a lot smaller anyway and a switch for the back light.
6,596
got any pics links ? :)
6,596
Why not leave the Intuvia where it should be and put the Garmin where the Intuvia now is.
he has Intuvia on a gen 1
6,596
6,596
its from a guys bike on the german forum but its held on with cable ties underneath.
the foam just helps clamp it on the frame.;)
Izzyekerslike
455
415
Leeds, West Yorkshire
What's the f##k is the point of that! :rolleyes:
Some people really should not be allowed anywhere near tools.
If you move the Intuvia to the crossbar position then it is better protected in the event of a crash, the Garmin edge Mount fastens on the stem with a small plastic Mount which is secured with two large "0" rings and in the event of an accident will separate from the bike which is exactly what happened when I had my off earlier in the year. So not really such a bad idea. 20160325_201546.jpg
Reactions: soundwave
6,596
its better there than on the handle bars ;) also checked all my rear bolts and none was loose.
cable ties staying tho :p
6,596
when it stops pissing down with rain, was off road today mostly on the pavement lol:eek:
also went past 2 plod cars going 32mph on the main road and not interested.:D
6,596
1 thing that is a pita is my hope disc rotors as near impossible to stop them hitting the calliper or rubbing on the brake pad front is worst.
the rivet on the disc where it is attached hits the calliper if not on right.
clears the mount fine, tho lot off ppl have same problem with it hitting there calliper.
6,596
