Pedalling will be the same, but the assist will cut out at a lower speed, 9mph i believe. Medium assist around 12mph and top assist around 15mph
Precisely what I was going to post but you beat me to it by 2 mins!
HOWEVER, I have just been for a ride today and played around with the 3 settings and now don't think it's as simple as this and quite confusing when riding.
The 4mph test is hard to pull off - it's a very slow speed so requires a contant hill of the right gradient. That said, I believe I got it to work once and all three assist levels seemed to deliver the same power.*
I think the issue is the way the power tapers off rather than hitting a wall at the limit. This means that at most speeds one or two of the assist levels will be offering reduced power and the higher setting(s) will therefore give more power.
I had believed until today that the taper for Medium assist was from about 9 to 12mph but since I can feel a boost in power from medium to high assist at speeds as low as 7mph the taper for Medium assist must start below 7mph (more testing needed). If that's the case then the taper for Low is likely to start below 4mph and that would mean I was wrong about all 3 assist levels delivering the same power at 4mph (* above)!!!
I found 7mph was a good test speed but still requires a constant gradient. All three assist levels are available. Low is at very much reduced power because it's only 2mph off cutting out altogether. Medium is only slightly reduced as it's only just starting to taper off and I presume High is at full power.
This starts to shed light on why I am getting such different distances out of the battery on the same route on High assist. Not only do I save power the more time I go over 15mph but I also save power the faster I go between about 9mph and 15mph.
Lots more testing needed!
Maybe one of the electronics gurus can explain this (in layman's terms PLEASE!! ).
I shall now put on my tin hat and retreat to the bunker ready for my theory to be shot down in flames!
