Part 3
Resulting in strangely shaped moulded fitting for pedelec sensor
Fitted parts back together when fully cured
(as before, will eventually paint epoxy resin matt black and should blend in very nicely but better to be white in photos for time being.)
Then refitted this after cutting the metal ring off and filing the sharp edges whilst leaving enough metal for the cable tie to hold the sensor in place. Also decided there was too much flexing of the pedelec disc so decided to add an extra blob of epoxy resin, drilled a hole for a cable tie and added an extra tie to hold it all firmly in place.
Meanwhile, new Avid 203mm rotor disc and 203mm post mount adaptor arrived.
This mod is needed otherwise there isn’t enough room for the hub motor with the original brake calliper mounting position for the original 160mm disc.
It also allows enough space between the spokes and the Avid brake calliper adjuster, but still only a couple of millimetres between them!
Next the controller housing and wiring.
There is a box supplied in the kit for the controller. It is suggested that it should be located on the seat tube, but the tube clamp on the box is too small for the frame on this bike and would interfere with the front changer cable so I decided to modify it.
First I cut off the seat tube clamp with a hacksaw
I later filled these holes with epoxy resin to seal it and to strengthen the now weakened box.
It was then a simple job to drill two holes in the box so that it could be attached by the secondary bottle cage mounts onto the seat tube. This was something I had not anticipated but worked surprisingly well. As before, I used a sheet of rubber cut from an old inner tube between the box and the seat tube to protect the frame.
I was finding it extremely difficult to screw in the connection to the battery – something that needs to be done every time the battery is put on or taken off the bike. The connector is almost inaccessible.
More epoxy resin required!!!
Extended the connector using electrical tape and cling film to protect the other parts
Removed cling film when set but left some electrical tape on a clamp that looked like it would be vulnerable in wet conditions.
Added a ring of rubber from an old narrow inner tube (lucky fit!) and that makes it very easy to grip. It’s now very easy to connect or disconnect the battery.
Fitted controls in place but disconnected and removed the thumb throttle as I don’t use it.
For me, the thumb throttle takes up room on the handlebars and it’s an extra wire to route around the bike. I reckon the best thing about an ebike is the pedelec sensor & if I put the bike in it’s lowest gear and turn the pedals I am unlikely to put any effort in whatsoever but the pedelec sensor will turn the motor on, so to my mind that is my throttle-only option.
Re-ran cables and neatened everything – notice the extra long cable behind the control box housing – this is the battery cable and it is about 1 metre too long! – I will shorten it when I’m totally happy that I don’t want to change the position of anything.
Cable connectors all fit inside the controller housing along with the controller but it’s a tight fit and I found I needed to place them inside very neatly for the lid to be closed.
Otherwise very little in the way of extra cabling to be hidden away – possibly a different story on a smaller frame!
Finished!
Problems remaining…
I really like the motor cut outs on brake levers but the kit only has a cut out switch attached to one of the two brake levers. This has occasionally caused me problems when I want to use the lever without the cut out on it’s own and it ends up working against the motor. I will try to find a solution to this if I don’t get used to it pretty soon.
The battery charger takes much longer to charge the battery than suggested. The manual says 3-4 hours and the longest I have charged it is just over 6 hours before I turned it off and went to bed. I was waiting for the charger light to go green but it never did, despite the battery showing the full 4 green lights after 5 hours. It also gets extremely hot as there is no fan in the charger and although this is to be expected it’s a bit unnerving to leave it running whilst unattended.
Weight…
The 23” bike was 14kg when it arrived and is now 21kg but I’ve still to add a pannier rack and some form of mudguards.
Shopping List…
23” Specialized Hardrock Sport Disc (2011) £440 from local bike shop. (Obviously I can’t vouch for how this kit will fit any other sized frame or bike!)
8Fun bottle battery 36V kit £435 incl. delivery via ebay.
Avid 203mm disc rotor £20 (on special offer) from an online bike shop.
Avid 203mm post mount adapter £9 from an online bike shop.
Bolts to fit post mount adapter (not supplied with adapter!) £1 from local bike shop.
Crank bolt allen key (8mm) £2.50 via ebay.
Crank removal tool suitable for Shimano Octalink cranks £6 via ebay.
Ding All 7” epoxy resin surfboard repair stick £11 via ebay.
100 pack of 4.8mm x 300mm cable ties £3.50 via ebay.
Total £928 (although I believe a computer is a necessity with an ebike to be able to either save power by going above the assisted speed or to easily cruise at just within the assisted speed to get full power benefits)
Other items that could add to the bill might be: helmet, pannier rack & ‘bag(s)’, mudguards, lights, pump & tyre repair kit, locks and basic tools… clothing… waterproofs… the list goes on…and on…and on… ££££££££
And what of the aim to have fun?...
Well, it certainly seems to be working so far…will let you know how it’s going after a few more miles.
(go back to Part 1)
Finished!
Problems remaining…
Weight…
Shopping List…
(go back to Part 1)
