Parallel batteries
3,994
How close do the 2xbatteries volts need to be when coonnecting up and using something like this?
Assuming normal lithium-ion batteries and assuming fully charged, I'd be happy to connect them in parallel up to 0.3v difference without that device. The difference would have to be about 2v before things start to get dangerous because that's the sort of sag you get when drawing normal current; however, it might not do the cells much good charging at 10 amps through the output terminals.
With the device, they can be anything you want, but I think my nerves would tell me to make them close before connecting.
Reactions: Nealh and Bikes4two
awol
1,216
374
When using these schottky diodes does current still flow between the batteries but controlled and very slowly or are the batteries electronically kept completely separate so you could just plug either one in and out to swap it whenever you want?
Sturmey
698
374
68
They dont have to be close at all. One battery can be fully discharged and the other fully charged. However (and this is very important), this is only the case where each battery individually is capable of supplying full current to the controller. So for example in my case, I often parallel my 11ah with another 13ah battery to supply a 14amp max controller to increase my range so no problems, as each battery individually can supply 20 amps peak.
A different situation exists when say someone has a huge motor with say a 25 to 30 amp controller and he has two batteries that are only rated at say 20 amp max discharge.
In this case the batteries need to be matched and similar voltage so that each supplies about 13-15amp ( or at least does not exceed 20 amps )and wont trip the bms.
8,734
The individual components aren't my thing and understanding board layouts I find confusing, can not the single schottky diodes not work then as well like the one below. Although 6a rated is has a 300a high surge current.
WheezyRider
1,690
938
It doesn't matter, current can't flow from one battery into the other with a diode set up.
The amount of current taken from each battery and sent to the controller will depend on the state of charge of each pack. If one is more charged up than the other, it will supply the bulk of the current until its voltage drops to match that of the other battery.
Reactions: awol and Bikes4two
WheezyRider
1,690
938
You'd have to put several of those in parallel, as you're likely to draw more than 6 amps continuous through the diode if only one pack is connected, or one pack is discharged.
But you can get 100V 60A versions that do the job that are cheap enough:
37530
The other advantage of this diode case format is that you can fit a heat sink directly on the diode, as you will consume a small amount of power.
Reactions: Bikes4two and awol
awol
1,216
374
Out of curiosity I want to make one of these leads, do I need 2 of these (one for each connected battery)?
17,153
you only need one, they have two diodes in each device.
Bikes4two
1,076
462
Havant
......... I want to make one of these leads, do I need 2 of these ..............?
This is not necessarily directed at the OP, but to those who on reading this thread, might have similar queries, and it is this:
Given that such a question as the above and other similar questions of a very basic nature have to be asked in the first place, I would advise that caution is exercised before embarking on the making of such a lead.
Yes, we are looking at simple circuitry here, but non the less there is a level of knowledge required to safely make up such a lead which, at the end of the day, is going to be joining two high powered energy sources together.
If you have no knowledge of anodes, cathodes, heat sink installations, insulating methods and so on, then I would advocate you look at something like the device @Woosh will be selling (post #12).
WheezyRider
1,690
938
If you want to make a Schottky diode "Y" adaptor for running two batteries in parallel, you need a diode in each leg of the "Y" (one for each battery).
The Woosh device, you only need one, but it only uses one battery at a time and then switches over when the primary battery is discharged.
WheezyRider
1,690
938
I agree, if you want to make a Schottky diode based adaptor and you are not sure what you are doing, get help. Don't risk blowing up two battery packs or worse...
3,994
Why don't you show him? It's not exactly difficult. He's been on this forum installing electric bike kits, etc for 7 years. He's not a dunce. That's what the forum is for.
WheezyRider
1,690
938
I hope I didn't give the impression I was talking to anyone in particular. I was talking generally to anyone who might be reading the thread.
3,994
My question still stands. The guy asked how to do it. Why don't you help him?
Just as an aside, we have a forum member Cwah. When he first came on the forum, he didn't know that you couldn't undo a hex screw with a flat-bladed screwdriver, but we helped him learn. He went on to make 3,000 posts and he became an innovator that we all learnt from.
WheezyRider
1,690
938
I agree totally. We are here to help, encourage and support each other. However, although this procedure is quite simple, it does need to be done with care as there is risk involved if it is not done properly.
So if anyone is not exactly sure what they are doing, they need to ask for help. If it goes wrong, expensive damage can result, or personal injury could occur.
WheezyRider
1,690
938
Will do, just need a bit of time. Probably won't be today though, got a load of other stuff I have to deal with. I'll try and put a how to together tomorrow.
Ok, here you go...
I've put it in the technical section, as I thought that might be more appropriate.
Bikes4two
1,076
462
Havant
Nice one @WheezyRider - I've read the write-up and it gives folks the key points to consider.
8,734
For paralleling any one who is thorough and makes sure voltage are very close so say
for 36v, 41.5v & 41.6v then there is no need to go down the mod route for your balance leads. Stick with the routine you already know and are happy with rather then go down the that will do road.
3,994
This is the approach I've always taken. It's no big deal to charge both batteries before connecting. Why would you want to use a half-charged one if you're going on a journey that needs two batteries?
Reactions: Nealh
