I recently purchased a new Kalkhoff Pro Connect LX from 50cycles,
I noticed that randomly it would develop a light metallic clunk when the left hand pedal reached the bottom of its travel, once this starts it is there for the rest of the journey. I looked closely to see if anything was loose and all I could find was horizontal travel in the pedal crank of about 1-2mm which when moved side to side resulted in a metallic clunk. I had only used the bike about six times at this point and contacted 50 cycles to see what they thought.
I was advised this was not normal and they promptly collected the bike, advising me that as it was brand new they would not strip it but fit a new motor.
In the meantime I purchased one of the Technicon Privilege bikes wiggle were selling for my wife, which is built in the same factory as the Kalkhoff and uses the same Panasonic drive unit.
When it came to having the bike returned from 50cycles I was told that they had looked at the new drive units in stock and they all had similar lateral travel in the pedal crank.
I was advised they had stripped the motor down and re-greased the bearings and could find nothing wrong.
Strangely the Technium has almost undetectable lateral movement and definitely no clunk.
Does anyone have any experience of this lateral pedal crank movement? And is this normal?
Due to illness I have not yet been able to test the Kalkhoff since its return, but hope to resume my commute next week.
I have been using the Technium in the meantime and it has been faultless.
