Personally I think there is a lot of hype around batteries. I have a theory, it is the motor and controller that makes more of a difference to battery longevity.
Panasonic crank drive systems are kind on batteries as during recent testing I struggled to get one to peak over 20A. The same tests on some well known hub brands resulted in peaks of up to 70A!
This is mirrored in model car racing. Over gear the car and run a high powered motor and your lipo packs struggle to last a season (regardless of them being el cheapo's or LRP packs at the top end of the spectrum). If you run a car suitably geared, with a lower output then surprise surprise your lipos last2-3 seasons. To put this into figures a high powered car, over geared, can peak at 100A compared to a much lower 30-40A for the same car, better geared and running a stock motor.
Running a crank system puts far less strain on a battery as the motor rpm remains more constant regardless of your actual speed. Over time I think this is kinder to batteries.
I hope this is right, otherwise I won't have a hope in hells chance of finishing the 24hr race this weekend!
