Oxygen Scross MTB ongoing review
Wisper Bikes
6,313
2,279
69
Sevenoaks Kent
Hi Mr Choo,
Even 7 miles a day each way will put a lot of miles on the clock quickly. Any of the bikes you have mentioned will do the job nicely. I wouldnt be tempted by the very cheap bikes on offer, they will eventually let you down.
All the best, David
Reactions: MrCh00
5,786
Very interesting thread. I'm new to these ebikes and I have my eye on this bike and also the Wisper 905 torque mk2. I did want the woosh Rio but unfortunately they don't accept cycle2work vouchers. Just not sure if these 2 bikes are a little of an over kill for me as I only commute 7 miles with a hill on the return from work.
My future commute is 2.8 km, I can walk that in about 30 minutes. Nice weather commute along the shore 4.2 km.
The problem is getting home after a nights work, there is 42 metres (138') to climb. With traffic it will be a 5 minute ride to work and I will be wearing shirt and tie with dress shoes - rain gear when necessary so it will be a full assistance twiddle the pedals commute both ways.
There is actually a bus line but the times are specially calculated by boffins with big computers so that they are as impractical as possible...
Andy Bluenoes
849
305
55
uk
I dont know if I would say overkill. If you are only commuting 7 miles each way, with a bike like the Oxygen, you are guaranteed many years of use from it before you get any problems. Whereas with some of the other bikes Ive had they wouldnt last anything like as long.
MrCh00
13
Lincolnshire
Thank you all for the responses. Now if I was to get the oxygen should I stick with the 10.4ah battery or go for the 13ah?
MrCh00
13
Lincolnshire
At just £50 difference, I'd choose the larger one.
True, Did wonder if to go with the halfords ebikes but some of the reviews put me off.
Just need to decide on this bike or the Wisper 905. I hope I can top up my £1000 c2w or cycle plus voucher.
17,116
Not sure if I can. I work for for Royal Mail and their scheme is halfords or cycle plus.
Woosh works with CyclePlus.
Not Halfords though.
Wisper Bikes
6,313
2,279
69
Sevenoaks Kent
I would be happy to ask Rob Howe the Greencomute MD to call your HR guys. A lot of big employers now offer Green Commute.
It’s more attractive to bike sellers too. The pay 5% not 15% commission.
All the best, David
MrCh00
13
Lincolnshire
All the best, David
That would be great thanks, there’s no harm in trying.
Andy Bluenoes
849
305
55
uk
Not sure if I should be a bit concerned, but how much play is acceptable in the front forks?
There is now noticeable movement between the fork piston and fork main section when stationary and you rock forward and backwards on the brakes.
Everything else still going strong, now at 5600 miles in.
Sent from my CMR-W09 using Tapatalk
RobF
4,732
2,312
Be afraid, be very afraid...
To be serious, the play you describe - assuming it's not the headset - doesn't sound too clever to me.
Worth getting the fork looked at by a competent mechanic.
A lot of cheaper forks are not serviceable, but a new budget fork is less than £100.
If it is replacement time, I'd be inclined to look at going rigid.
Cheap sus forks don't do a lot more than add weight and - as you are discovering - maintenance complication.
Reactions: Andy Bluenoes
17,116
those forks are not really serviceable, you've got a good run from it, install a new one, it's a 30 minute job.
Andy Bluenoes
849
305
55
uk
Cheers both, I'll get it checked out as soon as I can.
Here's a quick vid, but you cant really see where the movement is coming from, but it is definitely the tolerance between the inner and outer part.
17,116
that looks like from the headset, take the fork out, check the bearings, clean and grease. You probably won't need new fork but may have to spend £10 on new bearings.
Related Articles
