Doesn’t look anything suspicious with the 1t4,but i will try with a different one,i’ll order and see what is the outcome.thank you
Sir,thank you!This was it for the D type connectors. It'll be similar if not the same:
Actually, I think this is it. The above one is definitely oxygen before they changed to the coloured connectors. This one is probably Oxygen because the colours are in the same sequence as the other one, but there's a chance it's KT. The only difference between the two, is the position of the pedal sensor, which moved to a separate connector direct to the controller instead of going through the main harness:Sir,thank you!
Bafang is different to Oxygen.
a meter set to continuity should enable you to verify the pinouts, and if a match ..
