Done
. Spent today on and off fitting the kit. Rear wheel built and fitted with Torque arm,adapted fitted sensor ring works nicely which I attached to the chain ring. My reservations about the wiring came to nothing and no splicing of the wiring was necessary had to fit thumb throttle on the right. Fitted extra riv nut for battery mount all in all the kit wiring looks much neater than the BBS on my Norco. Decided to remove the reed switch with its connector and fit to my hyd brake, I drilled a hole through the back of the lever and having passed the reed through it threaded the attached hex screw in to the hole, magnets and sugru used on brake lever and a bit of heat shrink over the reed. Tested throttle and brake and all is ticketyboo hub switches on and off nicely
The only thing I am struggling with is the settings on the LCD haven't yet cyphered how to find and adjust wheel size, km to mph etc, etc all that I have managed is to go up and down with the assist levels 1-6.
Will post pics soon.
