Options for transporting ebike by car
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
Always padlock rack and bikes to towbar if being left unattended for even a minute or two.
I always lock/secure the bike and the rack to the towbar. Theft being one reason, and the second is that if the worst happened and the bike/rack fell off, at least I would be dragging it behind the car, and not having it potentially hit any vehicle that might be following.
Reactions: IR772
Yep, I've noticed that many of the tow bar mounted bike racks are only rated at 15kg per bike which is the same as most boot/hatchback mounted carriers and well below the weight of most ebikes.
Two I've shortlisted so far are the Witter ZX210 which is rated at 60kg max load and the Thule Europower 916 also rated at 60kg.
I'm not at all familiar with towbars. I've seen some that are removable or retractable, which would be my preference, but I have no idea what the pros and cons are.
I would not be worried about the Overall weight on the towball. I think that caravans are expected to exert up to 60 to 100kg downwards if memory serves. A fully loaded ebike including battery would typically be 25 kg , and without battery 22 kg or less. Since ordinary bikes not racing bikes could be 15 to 18kg , there is not much difference. The racks are capable of handling 3 to 4 bikes, depending on brand, so 1 to 2 ebikes should be ok. The greatest load is the pressure on the clamp, and the Thule models look very robust. The internal railings and mounting structure is likewise sturdy.
2Lazy
211
146
Milton Keynes
Thule raceway 2, if it fits. I've always had a tow bar until now, so opted for the best rear carrier i could that doesn't need tow bar and is easy to fit quickly. I also didn't want to try and lift bike onto roof and was worried i'd forget the height.
Towbar is best, but this imho is the best option without, problems it's expensive.
Thule raceway 2 would be ideal. But I notice that it's only rated at 15kg per bike. My Haibike is 23kg, so around 20kg with battery removed. I guess I could trim more weight by removing the wheels.
Presumably you've had no issues?
I'm getting some quotes for tow bar installation + a good tow bar mounted bike carrier but I suspect it's going to be well north of £500 which I really don't want to have to pay unless I absolutely have to. The Thule raceway 2 would be a good and much cheaper alternative solution if it can take the weight.
Crockers
821
689
71
I had mine fitted at Volvo. Their own branded rack is made by Thule. If Volvo have chosen Thule then you can be sure it's been rigourously tested.
Steve A
704
414
Ashford, UK
No problem with weight. The Thule raceway comes in 2 / 3 bike mode. Hence it's designed to carry 2/3 normal weight bikes which equates to more than the weight of your bike battery removed.
I've had no issues. It's not like other boot carriers, no straps etc. It has bike lock type cable which tightens via an inbuilt racket system and then locks with key so thief can't easily remove carrier or bike.
I change my car every 2/3 years now hence don't have the tow bars anymore, as on my car it's close to £900 fitted. However i have kept all my tower bike carriers for future.
The thule is easily to fit, store and is very solid. Best of all i can transfer to other cars.
Reactions: 2Lazy
baldylox
240
77
Hants/Wilts border
I agree with Eddie, security and stability of a tow bar mounted rack which is rated for the additional weight ensures peace of mind when transporting your bikes.
I use a Buzz Rack Scorpion mounted to a detachable swan neck tow bar.
http://www.roofbox.co.uk/scripts/rbvehsel4_tab.php?32999&gclid=CLTAh_OYq9MCFUefGwodHqgH1A
I can carry two eMTBs up to 30kgs each and drive a couple of hundred miles without any issues.
Sent from my Nexus 7 using Tapatalk
Reactions: 2Lazy and EddiePJ
Steve A
704
414
Ashford, UK
I think we all agree, but as stated if someone can't afford this option or is reluctant to fit a towbar then what are the other options if any.
bobp
18
17
72
Whitehaven Cumbria
Tow bar mounted Pendle rack carries my two haibikes no probs.
Couple of hundred quid to secure seven grand worth of bikes is what I call value for money.
Sent from my iPad using Tapatalk
Steve A
704
414
Ashford, UK
I've still got my pendle rack in garage, alas no towbar
.. there is .. insert a sheet of plastic, lino or similar in the boot space, for protection of the carpet , remove the front wheel and insert the bike with the saddle inmost. Then should the unthinkable happen, the driver will not be impaled by the front forks. That pleasure will be reserved for the radiator of the colliding car..
Reactions: Steve A
RoadieRoger
733
209
Use flexible polyethlene pipe insulation on each fork leg in conjunction with some nice heavy carpet between the bike and the seatback .Screwfix sell it in metre lengths for 79p to 99p depending on the thickness . If still doubtful use double thickness around each leg to please your Father !
Reactions: Steve A
asc99c
78
25
44
Are there any racks for carrying three e bikes?
The problem would be the nose weight most likely. You can get a list of allowable nose weights on the caravan club website, but for our last car, a large Citroen Grand Picasso, the limit was 60kg. That wouldn't cover three bikes plus the carrier itself. Some 4x4s do go much higher so depends on the car, but you might have to do two on the back, one on the roof.
Sent from my ONEPLUS A3003 using Tapatalk
2Lazy
211
146
Milton Keynes
It's not just the fact that it's hard metal tubing that's the issue. It's more the fact that the bike takes up all the spare space in the car with the front of bike pushed up close to the front seats. As such, in the event of an accident where I was badly rear ended the bike would have nowhere to go except forward, crushing the driver. No amount of pipe insulation is going to make it any safer!
I think I've managed to solve the problem though. I simply put the bike in rear end first with the back wheel pressed against the front passenger seat. Thus in the event of an accident the rear wheel of the bike (which is obviously a lot less sharp and pointy than the front end) should be pushed forward into the front passenger seat area. So in theory it should be safe(er) as long as there's nobody in the passenger seat. Not only should this be safer it's also a lot easier to get the bike in and out of the car rear end first.
Steve A
704
414
Ashford, UK
Did someone mention Citroen grand picasso, worst car i ever had. I honestly couldn't sell it as 3 dealers said the electrics were so bad they weren't interested.
Funny enough, the previous car i had to that was the original picasso and after 250k miles other than brakes, tyres etc it was a great car.
My current volvo xc90, brand new is a nightmare. So much tech you need to be a auto tech specialist to drive the bloody thing.
I say bring back wind up windows and me push button radio!;)
. If the back of the car got such a wallop as to start moving the bike forward, it would collapse the wheels , against the steel frame of the seat. If the amount of rear ending was such that the back had chrushed 26 inches, cycling would the least of your concerns.
2Lazy
211
146
Milton Keynes
The front of the bike is pressed hard against the front seats. The front forks are at an angle and litterally pressing into my back. With the sort of forces involved in vehicle accidents the merest of forward movement and I'd be impailled, in such circumstances the seat frame such as it is would do nothing to save me. Even if the wheel did collapse, and I'm really not sure that it would, the flesh and bone in my back isn't tougher than a 27"+ MTB wheel!
In any case I'm pretty sure I've managed to mitigate most of the risk by putting the bike in rear end first with the rear wheel pressed against the back of the front passenger seat.
