OK, it's not a bike, but it is electric... Bubble cars are back!
Waspy
459
188
Coming back to three wheelers and reverse gear.
I seem to remember a mate of mine turning up on christmas day (I was about 16) in an old Bond. Starting it meant lifting the bonnet and kick starting the engine, think it was a 250 villiers two stroke single. The engine was actually mounted on the bogey with the front wheel, so the chain drive was straight to the wheel. The engine turned with the wheel and you got reverse by actually turning the whole assembly through 180 degrees.
It was noisy, smelly, cold and slow but we didn't get wet cruising around on christmas day. What a hoot.
It was called a Bond Minicar, a mate of mine had one for a while in the early 1970s.
His had a 250cc twin cylinder Villiers engine, with the kickstart under the bonnet.
These air-cooled engines were developed principally as motorcycle units and therefore had no reverse gear. However, this was a minimal inconvenience, because the engine, gearbox and front wheel were mounted as a single unit and could be turned by the steering wheel up to 90 degrees either side of the straight-ahead position, enabling the car to turn within its own length.
A method of reversing the car was offered on later models via a reversible Dynastart unit. The Dynastart unit, which doubled as both starter motor and dynamo on these models incorporated a built-in reversing solenoid switch. After stopping the engine and operating this switch the Dynastart, and consequently the engine, would rotate in the opposite direction.
They were made in Preston, Lancashire, between 1949 and 1966.
Reactions: kevsbike
Benjahmin
2,642
1,775
70
West Wales
The very thing ! An example of those ingenious, yet desperate, post war methods of getting a brassic and worn out population mobile.
Capatilising on the ability of a simple two stroke to run backwards probably meant you could still drive it on a bike licence as it technically had no reverse gear. Perhaps my memory is faulty on the 180 degree engine rotation thing and reverse running is what my mates car did. I was only 16 and life was still a mystery.
Reactions: Ghost1951
jimriley
611
407
I've ridden one of those.
I have something very similar, without the crossbar, a set of handlebars forks and wheel for my unicycle. Pulling a wheelie is easy.
I've also used a set for the 5ft giraffe unicycle, ideal for coping with the current floods to keep one's sox dry .
Reactions: MikelBikel
AndyBike
1,596
667
6,689
date says made in 1997 and cost $1000 i paid 300 delivered upgraded the lumber support and new soft arm rest on way for 100 quid and a spare normal foam lumber support.
the head rest is $150 on its own :p
MikelBikel
1,557
385
Those wheels are too small, hehe, they'll get caught in the potholes :)
3,706
Mate, you poor guy having to do that to get a seat that's shite, though there is a way out. Unbolt the seat and chuck it. Look on Ebay for a Recaro seat, ideally electric orthopaedic, like my other one that has electric pump up lumbar and shoulder, electric recline, heating and everything else adjustable. Cut and drill a sheet of 12mm plywood as an adapter. Bolt the seat to your base. Enjoy the insurpassable comfort while you work or play.
I bought mine in 1994 for £400 when I worked for Recaro. They're still going strong after 30 years.
61802
