I thought you might go for it in the end. Really pleased you made a decision - and you've certainly done your homework to rationalize and understand your choices which is great. Well, nothing ventured nothing gained and in all honestly it sounds spot on for you both. Really interesting feedback, thanks for putting it up.
It's nice to have the suspension there for when you need it though - especially if you're going to be going on tracks a fair bit.
LOL. OH the humour in thatThe location of the 50Cycles unit in Loughborough is such that whilst easy to find and park (Driving Test Centre appears to be co-located so plenty of 'L' plates manoeuvring in the car park)
.. ouch ... hope you told them .. can wind up a pricey old fix if they're ridden with slipping gears ... don't think it does the hub innards any good at all ! Similar thing can also happen if you put excessive pedal effort in too low a gear (i.e. change up too late - closely followed by pedals spinning freely). I often ride bikes hard and it's one of the reasons I like a big range.The i8 had the Nexus 8 speed hub (no Alfines yet) and unfortunately it was maladjusted so gear changing was largely an unpleasant experience accompanied by snatching pedals and crunching noises from the back end.
Highly likely a bit of both. The run-off is very smooth on Impulse bikes and at higher speeds you pretty much feel no more than a gradual reminder of the limitations of the bike's (and your own physical) capabilities. I genuinely believe extra gears make a huge difference - if you have the fitness to use them.The transmission of electric power was very smooth indeed but thinking back now even at fullish tilt in 8th gear I wasn't aware of hitting 'the wall' so either I wasn't going fast enough (gearing maybe a bit low for me?) or the run off of power was so smooth that I just didn't notice it.
That's about what I'd expect. I have to use gears 9-11 and adopt a sportier frame of mind to crack those speeds on the flat on mine. If you tested the 26" version you may find the 28" a little faster above 15.5mph - albeit it'll be harder work uphill in that range - if you ever use it there.The bike did feel as if had effective gear ratio wider than the Nexus 8 but I slipped up in not trying it in manual gear selection mode and going for the highest ratio to see what that produced. The best speed I managed was 20 mph downwind and 18 mph the other way. I have no idea what pressures the tyres were at although the battery was over half charge. I was aware of the power being off at 20 mph but my perception was that the effort required to maintain speed was no or little different to a normally geared bike.
... and this is, I think, where this system will have widespread appeal. It's like having the simplicity of a single speed but with the relative benefits of gearing range for when conditions make that appropriate.In that mode the bike is a real 'dawdle' to ride and I have to admit that I immediately felt at home just cycling and not having to think at all about changing gear.
I'm not sure what the Big Apple tyres are like off-road but they were pretty comfortable on the short track of tar I tested them on. On-road I have to confess, I actually lock out the front suspension unless the road's really bad. The C11 has a suspension seatpost which makes a big difference and really comfortable upright riding position so don't really feel the need for front suspension much ... and bike feels a lot stiffer for climbs locked out too.The ride was very comfortable on the Big Apple tyres and we both agreed that it was easily the more comfortable of the bikes to ride even though it does not have suspension forks like the I8 Nexus.
It makes a huge difference on a crank drive, and the triple-sensor input of the bikes you've bought makes them even more intuitive. Not all torque sensors are responded to equally either. It was after the penny finally dropping how significant this impact was to the ride 'feel' that I ruled out a crank drive conversion. It's all in the controller software with a PAS - provided you have the inputs available to begin with !There is only one reason why I didn't come home and immediately reserve two Santana CDs and that's the absence of a torque sensor.
