Nuts always getting loose
cwah
3,048
179
www.whatonlondon.co.uk
Hello all,
The nuts of my rear wheel motor always get loose. I'm using the leafbike 1000W motor:
http://www.leafbike.com/products/e-bike-hub-motor/gearless-20-24-26-700c-28-inch/newest-20-inch-48v-1000w-rear-hub-motor-wheel-888.html
What's best to avoid this issue? Shall I get thread lock?
http://www.hobbyking.com/hobbyking/store/__69125__HK_175_Thread_Locker_Sealant_High_Strength_Green_UK_Warehouse_.html
Or shall I get some 14mm nut with Nylon?
http://www.ebay.co.uk/itm/A2-Stainless-Steel-Nyloc-Nylon-Nuts-Type-T-ALL-SIZES-/181741928865?var=&hash=item2a50a9c1a1:m:mikfwAaOAW9kwxZ4uQYvCgA
I'm thinking maybe nylon nut would be better as I would be removing the wheel from time to time. With thread lock it may not be as simple
8,843
Either would be ok or you could try a spring washer if there is room.
RoadieRoger
749
217
Clean the mating parts with cellulose thinners or similar and apply non-setting thread locking compound . I have used it on the rear spindle nut on my Scooter instead of the £10 single use only Aprilia Spares nut . A socket undoes it ok , the Torque is 80lbf.ft a lot more than on your Ebike !
8,843
The sprung tension against the nut should stop and loosening from vibration also a star washer should also work. As your nut is coming loose I can only assume that the thread size is not exact and there must be minute play.
Reactions: cwah
cwah
3,048
179
Nylocs.....but don't forget to use new ones every time you change....to work properly the nylon insert is one time use.
KudosDave
i don't want to change nuts everytime i get a flat tyre!!
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Yes you do,if you don't want them coming loose.
Anyway,how often do you get a flat?
We used to use nylocs on race cars in preference to castellated nuts and split pins,because Nylocs were so much quicker to undo,but you have to use a new one every time,the nylon loses its grip once the thread is cut within it.
KudosDave
6,733
get me some of that for me sunglasses bolts ;)
danielrlee
1,401
726
Westbury, Wiltshire
torquetech.co.uk
Nord Lock washers. As effective as a trip to the local sexual health clinic when it comes to solving your nut problems. They're an amazingly simple solution and you'll wish you'd have tried them long ago.
Reactions: cwah
cwah
3,048
179
Is it this?
http://www.ebay.co.uk/itm/10-Nord-Lock-Nord-Lock-Sicherungsscheiben-Keilsicherungsscheiben-DNL-14-verzinkt-/111832103217?hash=item1a09b67931:g:fF0AAOSwHQ9WVBd-
Or maybe this one is cheaper
http://www.ebay.co.uk/itm/M14-A2-STAINLESS-STEEL-SHAKE-PROOF-INTERNAL-SERRATED-LOCK-WASHERS-PACK-OF-10-/390927758854?hash=item5b051c3606:g:fZcAAOSwZVhWTa8A
danielrlee
1,401
726
Westbury, Wiltshire
torquetech.co.uk
The first link are the ones, assuming it is 14mm that you are after. I know they seem expensive, but put that aside and buy them. Don't bother with the second link. They are junk and nothing like Nord Locks.
8,843
danielrlee
1,401
726
Westbury, Wiltshire
torquetech.co.uk
Trust me, Nord Locks are the business. They actually expand as you apply torque to the securing nut in an anti-clockwise direction, making it almost impossible for the nut to come undone on its own.
8,843
See what you have done now Cwah :rolleyes:. A simple question and you get a multitude of answers a real can of worms you have opened :(, all you have to do now is decide which worm to go for.
Reactions: cwah and danielrlee
