Hi All
I have just aquired a Diamondback bike with a 48volt rear wheel conversion fitted, this was previously working fine but dont have any more info than that.
I have checked the battery and it charges and holds charge, all the wiring connectors from the controller and motor etc seem ok.
There is a large twin plug which connects to the battery which I assume is the main power, at the side of this is a small 3 pin round socket were the charger connects.
There is also a 6 cable round flex that is taped with the main battery connector which looks like it should connect to the 3 pin round socket but the plug is missing.
I do not get any life from the controller even with a fully charged battery and suspect it has something to do with the 6 core cable and missing connector that is not allowing the controller to fire up.
Does anyone have any ideas or info please, it would be much appreciated.
