newbie - help with Giant Twist RS2.....
Everything is standard Chines stuff, so it should be easy. Pull the controller all the way out so that you can get at all the connectors. First check that you have battery voltage on the thick red and black wires. Use a meter.
Now you need to check the throttle or pedal sensor connector. There should be 5v between the red and the black wires when the controller is switched on.
Pull it all out and take a photo so that we can see all the connectors.
