New Woosh Crank-drive Bike
  • Start date
Old_Dave
1,211
Dumfries & Galloway
Can of course be removed but only for servicing,
So I should imagine that the charge / discharge leads can be unplugged for 'servicing'.. if that's the case then it shouldn't be very hard to make an extra charge lead.
However as the bike folds nice and small then just stick it under the kitchen table and charge it there :p
pugsly
10
So, on the web page, it says the bike is good for riders over 100kg... So far so good. What's the max weight for rider? (I'm a big guy)
My posts were stuck in limbo for some time, but now fixed. Can I ask the above question again (its buried down the thread somewhat now)
17,440
Hi Pugsley,
You don't say how much you weigh or how tall you are. The Sirocco and Zephyr CDs are suitable for anyone between 5 ft 4" (although that is a bit on the short side) and 6 ft - but over that and you would probably need a larger frame.
The 100KG is a limit we tend to place on our models with rear hub motor, as these are quite likely to stall going up steep inclines if you are over this weight.
The CD versions are different and will take more or less any weigh because you can always select a lower gear if needed.
Hope this helps but PM me with more details if you like.
Hatti
RobF
4,732
2,312
Hi Pugsley,
Hatti
Hatti,
Seems Pug is a big lad in a big country, according to his thread here:
http://www.pedelecs.co.uk/forum/introduce-yourself/13760-another-big-aussie-guy-looking-ebike.html#post169653
pugsly
10
Hi Pugsley,
Hatti
Hi Hatti,
I'm 6' and 150kg. Motor is one of the concerns I have when buying an ebike (wheels and frame being the others). I've seen a number of bike quote a max rider weight. I'd be shipping the bike abroad, and warranty would be challenging, so the last thing I want to do is buy something where if it breaks I get told "hey, you're way too heavy for that bike - we're not going to help you".
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Pugsley.....I have sold a number of Kudos Duke bikes to big guys,one guy on the Isle of Wight customised his with a bugle and white wall tyres and moody paint job,quite the local celebrity.With a big guy,battery at the back the rear end weight is considerable-the back wheel is the weak point and we usually have to build a stronger spoked back wheel at a wheel specialists.
I must say that we have stopped supplying bikes abroad because of damage in transit and warranty considerations,150kg is some size----sir been weightlifting!!!!! The Duke is a big mans bike and very strong frame. I would have no problem with the motor,the Bafang motor is a very reliable unit.
But as others have said.....I can recommend the Duke,but sorry no warranty.
Dave
Kudoscycles
Dave
Kudoscycles
IMHO the motor doesn't have enough torque for a 150kg rider. It would stall on hills that aren't even steep, with a risk of burning out or internal gear damage. OP needs a much stronger geared motor like a Bafang BPM/CST, Heinzmann, Ezee or a MAC, otherwise it has to be a crank-drive.
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
ElectricDave.....you are probably right,I must say I have not supplied a bike to a rider of that weight,even whilst i was making the post I was thinking that a BPM motor would be stronger,but that would mean custom building the bike and Kudos does not offer that....he would be too big for our crank drive bike.
KudosDave.
Do you mind being called ElectricDave?....perhaps we could also have WisperingDave,hehe?
KudosDave
KudosDave
You can call me anything you like. I don't mind. Most people call that fat bar steward, which I can't understand because I've never worked in a bar.
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
ElectricDave....you just seem to be the guy on here who kindly and with patience sorts out most peoples electrical problems.....I seemed to have been nicknamed KudosDave by others and happy to inherit it.
Its just that there are so many Daves on this site that request for replies can be confusing at times.
KudosDave
It's tempting to think that there is a mysterious affinity between the name David and e-biking, but in truth there was a huge surge centred on 1960 in the popularity of David as a boys name. During the years around then the name David ranked in 1st, 2nd or 3rd in the names chosen for babies. In 2011 13,098 babies were named David, in 1960 it was a huge 85,927.
So we just have an extremely large proportion of Davids in the region around 50 years of age now, very much an e-biking and business management age band.
Details on this link
17,440
Hi Hatti,
Pugsley
I think the issue with your 150Kgs is not so much the motor. The crank drive models that we offer (CD) should be able to cope with that. But as I said before, what may still cause problems are spokes breaking, particularly if you pedal very energetically, the lateral stresses can break the strongest spokes.
I think you can tie and solder your spokes to make the wheels stronger or get a specialist wheel builder to replace the wheels with something that isn't going to let you down.
I do concur with KudosDave about the warranty. If you are taking this bike abroad and you need to ship it back to us for servicing (you might need to at some point) and back out to you again, then you would have to bear the cost of this....something you need to take into account.
Having said all this I am confident that crank drive models are definitely better for heavier riders and unless someone is extremely weighty, ours should fit the bill.
C
Cyclezee
As already mentioned in post 13 of this thread http://www.pedelecs.co.uk/forum/introduce-yourself/13760-another-big-aussie-guy-looking-ebike-2.html#post169953, eZee have bikes that would be suitable for Pugsley, there are the two verasatile Expedir models and the Yuba el Mundo which can carry up to 200Kg.
Alternatively he could have a good strong non powered bike with a front wheel conversion kit and I am sure the eZee motor is 'man enough' for the job.
The other plus point is that eZee have a worldwide network of distributors and dealers.
C
Cyclezee
Hi Pugsly,
There are 2 dealers with eZee bikes near you:
Cargo Cycles
eZeebike full stockist
44 Glasshouse Road
Collingwood VIC 3066
Ph: 03 9942 3450
Mob: 0417 352 782
Website
Melbourne Electric Bicycles
382 St Kilda Road
St Kilda VIC 3182
Ph: 03 9939 9894
Website
Glowworm in Sydney have the new Expedir models in stock, so they could supply to the Melbourne dealers.
It could be worth giving Maurice Wells at Glowworm a call or email. his contact details are:
Phone
(02) 9569 9126
Note: They do not have an answering machine and they only have one phone line. If it is busy (it often is) please try again in 10 minutes or send an email.
Email
info@glowwormbicycles.com.au
Regards,
Wisper Bikes
6,341
2,297
70
Sevenoaks Kent
Thanks for the link Dave, interesting.
It Peaked in 1955 at 86,171, when I was bought into the world. Although I am really Edward David I have always been known as David.
pugsly
10
