The Marin went pretty well. That was about 5 years ago when things were different. The bike arrived cheaply, and that was the only motor I had to hand at the time. Top speed was about 22 mph, IIRC, and hill-climbing was very good because it ran at 30 amps, which is about double most of the OEM bikes. It had two 10Ah 36v batteries in parallel. They were left over from other projects.
You can fit a motor to a front wheel if you know what you're doing, but I wouldn't advise it unless you have steel forks. A back motor is better anyway. If you look very carefully, you can see steel reinforcements running up the front of the fork from the drop-outs up to about 6". They're tapered, so hardly noticeable.
