New site
rsscott
Administrator
Staff member
Aug 17, 2006
1,399
196
Mike,
there is a thread in the main forum now for people to discuss what they want the titles to be, if anything.
They are based on number of posts, so that needs to be taken into consideration too. Alternatively a single title could be used regardless of activity.
Wander
586
429
Hi Wander,
I too use the 'Whats New' button a lot!
There are now 2 extra levels. From homepage you have to click on Forum on top bar> Then below that is the 2nd bar, hover over 'Forums' then click on 'New Posts'..
Rather annoying as before you could click this from any page on the site. Im sure Russ will add it to the top menu as a quick link.
Regards
Martin
Thanks Martin
That worked for a while however now the drop down doesn't seem to drop down any more!
You don't have to do two clicks. You just move your mouse pointer to "forum", and then "new posts" is in the drop - down. You can do it in one movement after a bit of practice.
peerjay56
745
201
Nr Ingleton, N. Yorkshire
Thanks Martin
There was some sort of a problem with the dropdown menus earlier, which now seems to be fixed;) I also couldn't write any pm's, so had to use the 'contact us' form to flag the problem up to Helen and Russ.
That's weird. Everything has worked perfectly for me.
Wander
586
429
Yep fixed ,now!
I found viewing the site in compatability mode fixed the problems with PMs etc.
Further problem:-
Signatures don't show unless you are actually logged in (they showed logged in or logged out on the old site).
Artstu
2,421
925
I had the exact same problem, also couldn't post a message, so used the contact us tab too.
Reactions: peerjay56
rsscott
Administrator
Staff member
Aug 17, 2006
1,399
196
Hi folks,
This problem was caused by the ad system as I was testing out a feature.
Russ.
Yamdude
842
639
Somerset
One thing that really bugs me about this new forum, is how the 'New Posts' work.
When I'm not signed in to the forum I can see all the threads with new posts listed.... as soon as I sign in, threads I've posted on are not there and I have to then search all the sections of the site.
