Do you think all this effort was necessary? Theoretically TSDZ2B should be OK without extra support.Finally some progress. Other things have been getting in the way. The main obstacle has been the problem of how to deal with the torque reaction from the motor on a full-suspension bike, so here's how I did it, which can easily be copied by any of you lot. All you need is some 2.5mm steel plate/strip of any metal that has similar stiffness, then a drill and a file/angle grinder to shape it.
There isn't quite a straight line from the fixing point on the motor's anti-rotation plate, so you need to file or grind a slight scallop in one edge.
I would say that the friction from the bracket on the BB has no chance of resisting the motor's torque. That's why they ptovide their own anti-rotation arrangement.Do you think all this effort was necessary? Theoretically TSDZ2B should be OK without extra support.
I was wondering what this extra hole in bracket is for. Now I know![]()
It is added there as extra measure. TSDZ8 don't have this extra bracket and it is expected to stay in place. One way or another your solution won't hurt for sure.I would say that the friction from the bracket on the BB has no chance of resisting the motor's torque. That's why they ptovide their own anti-rotation arrangement.
The TSDZ8 has a different bracket. I wouldn't rely on it anyway, plus it ruins your BB.It is added there as extra measure. TSDZ8 don't have this extra bracket and it is expected to stay in place. One way or another your solution won't hurt for sure.
TSDZ2B and TSDZ8 brackets are almost the same. Just TZDZ8 is a little bigger. I hope it will hold. If not I will send it all back to WOOSHThe TSDZ8 has a different bracket. I wouldn't rely on it anyway, plus it ruins your BB.
Just make sure that your ring-nut is nice and tight!
Unfortunately tools provided by Tongsheng are not very impressive. For that I might need my own gizmo. Two bolts and longer handle should do the trick.Just make sure that your ring-nut is nice and tight!
Sounds like a decent torque wrench substituteWhack the tool a few times with a lump hammer, which is what I did.
Did you see my mate? Fat guy with a fishing rod. Looks exactly like Shrek, but with a beard and tattoos. He keeps offering me fish pies baked by his daughter, don't think he likes them.It was down Ironbridge Gorge and back
You have to take one for the team sometimes. It's not too bad because it's the 48v version., but I do need to pedal harder most of the time, but not when I'm climbing very steep hills. I went up a 30%er today, which was at the end of a a long climb of about a mile. It's for a project that needs very good climbing torque, and there are reasons it would be difficult to use a rear hub motor, in particular because I need a special axle.Mid-drive? Torque sensored? I thought you hated both. Does not compute!![]()
I look forward to reading about how long your TSDZ2 lasts being used like that!I went up a 30%er today
It's ok for you and @Nealh to use tiny mid-dives then, because TSDZ2s are only ickle. So small and girly, they hardly countYou have to take one for the team sometimes.
