Hi Benjy,
To clarify a couple of points if I may, we only have a couple of customers in the UK using Mk1 eZee kits with the V1 motor and 48v 10Ah eZee batteries, supplied on the understanding that they are for use on private land.
Most people seem to be happy with a 37v setup.
Currently we have no stock of 48v batteries and will only supply on special request to someone who is not going to use it on public land.
This combination, i.e. V1 eZee motor and 48v battery, has been marketed by ebikes.ca to the North American market for a long time and has a proven record of reliability.
As we are all aware US and Canadian regulations are quite different from the EU and higher performance is allowed.
I personally don't regard the eZee motor as a low powered motor and V2 which you have even less so.
For your particular setup, I think a Cycle Analyst would be more suitable and give greater flexibility to alter the performance parameters than the control box / battery console (shown below) that now comes with the Mk2 kits. Unfortunately the latest version of the direct connection CA that is compatible with the new eZee wiring loom is not available yet.
For those who have not seen the new console before, in addition to being a battery gauge and power level selector, it has different mode settings which can be seen below.
Menu 1: Mode Selection
Mode 1 (Default): Pedelec / EBike (US): Power Led Bar shows the assist power level. When throttling, it switches to EBike mode.
Mode 2: Pedelec (EU): Power Led Bar shows the assist power level. Throttle will be limited to 6km in EBike mode.
Mode 3: Not in use. For future development.
Mode 4: Pedelec (EAF): Responds to throttle/EAF. Power Led Bar Bar shows the current (amps) level.
Mode 5: EBike (Cruise): Responds to throttle (from gauge). Power Led Bar shows the current (amps) level. ‘Up▲’ button set cruise. ‘Down▼’ button turn off cruise. EBrake will also disengage cruise.
With regard to the controller and heat dissipation, the stainless steel mounting plate supplied does help considerably and acts as a heatsink as do the controller mounting plates on the eZee battery rack/carriers.
