Powacycle Lynx Intermittent/Hard Faults
I have a similar fault on a month old Powacycle Lynx LPX, I have emailed Powacycle to find out whether they have had many ebikes with similar symptoms. I have asked Powacycle the following, and will post the reply ;-
A grinding noise, I think it is electrical not mechanical, emanating from the rear wheel motor hub, then the motor goes dead. I have four questions for you, perhaps you could answer each question.
1. What is the mortality rate of the control board ?
2. What is the mortality rate of the electric hub motor ?
3. Does the Control PCB suffer from connectivity problems ?
4. Would I contravene the warranty if I were to reseat the electrical connections on the Control PCB ?
From my experience of repairing electro-mechanical devices, failed or failing connectivity is the most likely cause of some intermittent faults. The fault on the Lynx was intermittent on yesterdays riding session, but a hard fault on today's riding session, prior to the 14th June the cycle has behaved beautifully and was well pleased with it, the cycle is just one month old.
Regards Terry
Regards Terry
